05-27-2015 09:20 AM - edited 03-05-2019 01:33 AM
881 returned from the field due to wan connectivity failure. large number of 881's still deployed with no problems. config has been reset, just basic ip setup now. FastEthernet4 / FE WAN interface will not remain up - sh / no sh brings it up for a few seconds before it shuts down again. pc connected to F0 / Vlan1 is able to ping the interface ip address for those few seconds before it shuts down again. ethernet cables + test switch worked fine for another 881. duplex & speed auto vs 100/full has no effect.
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.1(3)T1, RELEASE SOFTWARE (fc2)
Cisco 881 (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
5 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
Device# PID SN
*0 CISCO881-SEC-K9
Router#sh ip int brief
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset down down
FastEthernet2 unassigned YES unset down down
FastEthernet3 unassigned YES unset down down
FastEthernet4 192.168.4.190 YES manual down down
Vlan1 192.168.250.1 YES manual up up
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 192.168.4.190 255.255.252.0
duplex full
speed 100
interface Vlan1
ip address 192.168.250.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.4.1
FastEthernet4 is down, line protocol is down
Hardware is PQII_PRO_UEC, address is 0007.7d6d.b3c2 (bia 0007.7d6d.b3c2)
Internet address is 192.168.4.190/22
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input never, output 00:10:04, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes
Received 0 broadcasts (0 IP multicasts)
0 watchdog
38 packets output, 7308 bytes, 0 underruns
0 output errors, 0 collisions, 9 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
Router(config)#int F 4
Router(config-if)#sh
Router(config-if)#no sh
Router(config-if)#
*May 27 15:21:10.211: %LINK-5-CHANGED: Interface FastEthernet4, changed state to administratively down
*May 27 15:21:12.531: %LINK-3-UPDOWN: Interface FastEthernet4, changed state to up
*May 27 15:21:13.531: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4, changed state to up
*May 27 15:21:16.299: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4, changed state to down
*May 27 15:21:17.299: %LINK-3-UPDOWN: Interface FastEthernet4, changed state to down
Router#debug int states
interface state transitions debugging is on
*May 27 15:23:17.299: [IDB Fa4 DDRUnn] CSTATE_TMR: Entry
*May 27 15:23:17.299: [IDB Fa4 DDRUnn] CSTATE_TMR: netidb=Fa4, linestate: n
*May 27 15:23:17.299: [IDB Fa4 DDRUnn] CSTATE_TMR: starting lineproto timer
*May 27 15:23:17.299: [IDB Fa4 DDRUnn] CSTATE_TMR: Exit
*May 27 15:23:18.299: [IDB Fa4 DDRUnn] LSTATE_TMR: Entry
*May 27 15:23:18.299: [IDB Fa4 DDRUnn] LSTATE_TMR: not spoofing, current state: n
*May 27 15:23:18.299: [IDB Fa4 DDRUnn] LSTATE_TMR: informing line state transitions
*May 27 15:23:18.299: [IDB Fa4 DDRUnn] TRANS_ADJ: Entry
*May 27 15:23:18.299: [IDB Fa4 DDRUnn] TRANS_ADJ: Exit
*May 27 15:23:18.299: [IDB Fa4 DDRUnn] ROUTE_ADJ: Entry
*May 27 15:23:18.299: [IDB Fa4 DDRUnn] ROUTE_ADJ: Exit
*May 27 15:23:18.299: [IDB Fa4 DDRUnn] LSTATE_TMR: Exitnf
Router(config)#int F4
Router(config-if)#
*May 27 15:23:35.299: [IDB Fa4 DDRUnn] CSTATE_REQ: Entry, requested state: D
*May 27 15:23:35.299: [IDB Fa4 DDRUnn] CSTATE_REQ: starting ctimer (2000)
*May 27 15:23:35.299: [IDB Fa4 DDRUnn] CSTATE_REQ: state assign
*May 27 15:23:35.299: [IDB Fa4 DDRUnn] LSTATE_REQ: Entry
*May 27 15:23:35.299: [IDB Fa4 DDRUnn] LSTATE_REQ: Exit
*May 27 15:23:35.299: [IDB Fa4 DDRUnn] CSTATE_REQ: Exit
*May 27 15:23:36.883: [IDB Fa4 DDRUnn] CSTATE_REQ: Entry, requested state: A
*May 27 15:23:36.883: [IDB Fa4 ADRUnn] CSTATE_REQ: state assign
*May 27 15:23:36.883: [IDB Fa4 ADRUnn] LSTATE_REQ: Entry
*May 27 15:23:36.883: [IDB Fa4 ADRUnn] LSTATE_REQ: Exit
*May 27 15:23:36.883: [IDB Fa4 ADRUnn] CSTATE_REQ: Exit
*May 27 15:23:36.883: [IDB Fa4 ADRUnn] CSTATE_REQ: Entry, requested state: A
*May 27 15:23:36.88no sh
Router(config-if)#3: [IDB Fa4 ADRUnn] CSTATE_REQ: state assign
*May 27 15:23:36.883: [IDB Fa4 ADRUnn] TRANS_ADJ: Entry
*May 27 15:23:36.883: [IDB Fa4 ADRUnn] TRANS_ADJ: Exit
*May 27 15:23:36.883: [IDB Fa4 ADRUnn] ROUTE_ADJ: Entry
*May 27 15:23:36.883: [IDB Fa4 ADRUnn] ROUTE_ADJ: Exit
*May 27 15:23:36.883: [IDB Fa4 ADRUnn] BRIDGE_ADJ: Entry
*May 27 15:23:36.883: [IDB Fa4 ADRUnn] BRIDGE_ADJ: Exit
*May 27 15:23:37.299: [IDB Fa4 ADRUnn] CSTATE_TMR: Entry
*May 27 15:23:37.299: [IDB Fa4 ADRUnn] CSTATE_TMR: netidb=Fa4, linestate: n
*May 27 15:23:37.299: [IDB Fa4 ADRUnn] LSTATE_REQ: Entry
*May 27 15:23:37.299: [IDB Fa4 ADRUnn] LSTATE_REQ: timers not running
*May 27 15:23:37.299: [IDB Fa4 ADRUnn] LSTATE_REQ: Exit
*May 27 15:23:37.299: [IDB Fa4 ADRUnn] CSTATE_TMR: transition detected
*May 27 15:23:37.299: %LINK-5-CHANGED: Interface FastEthernet4, changed state to administratively down
*May 27 15:23:37.299: [IDB Fa4 ADRUnn] TRANS_ADJ: Entry
*May 27 15:23:37.299: [IDB Fa4 ADRUnn] TRANS_ADJ: Exit
*May 27 15:23:37.299: [IDB Fa4 ADRUnn] CSTATE_TMR: Exit
*May 27 15:23:38.035: [IDB Fa4 ADRUnn] CSTATE_REQ: Entry, requested state: U
*May 27 15:23:38.035: [IDB Fa4 ADRUnn] CSTATE_REQ: starting ctimer (2000)
*May 27 15:23:38.035: [IDB Fa4 UARUnn] CSTATE_REQ: state assign
*May 27 15:23:38.035: [IDB Fa4 UARUnn] LSTATE_REQ: Entry
*May 27 15:23:38.035: [IDB Fa4 UARUnn] LSTATE_REQ: Exit
*May 27 15:23:38.035: [IDB Fa4 UARUnn] CSTATE_REQ: Exit
*May 27 15:23:38.035: [IDB Fa4 UARUnn] CSTATE_REQ: Entry, requested state: R
*May 27 15:23:38.035: [IDB Fa4 RARUnn] CSTATE_REQ: state assign
*May 27 15:23:38.035: [IDB Fa4 RARUnn] LSTATE_REQ: Entry
*May 27 15:23:38.035: [IDB Fa4 RARUnn] LSTATE_REQ: Exit
*May 27 15:23:38.035: [IDB Fa4 RARUnn] CSTATE_REQ: Exit
*May 27 15:23:38.035: [IDB Fa4 RARUnn] CSTATE_REQ: Entry, requested state: U
*May 27 15:23:38.035: [IDB Fa4 UARUYn] TRANS_ADJ: Entry
*May 27 15:23:38.035: [IDB Fa4 UARUYY] TRANS_ADJ: propagating change to subifs
*May 27 15:23:38.035: [IDB Fa4 UARUYY] TRANS_ADJ: Exit
*May 27 15:23:38.035: [IDB Fa4 UARUYY] ROUTE_ADJ: Entry
*May 27 15:23:38.035: [IDB Fa4 UARUYY] ROUTE_ADJ: Exit
*May 27 15:23:38.035: [IDB Fa4 UARUYY] BRIDGE_ADJ: Entry
*May 27 15:23:38.035: [IDB Fa4 UARUYY] BRIDGE_ADJ: Exit
*May 27 15:23:40.035: [IDB Fa4 UARUYY] CSTATE_TMR: Entry
*May 27 15:23:40.035: [IDB Fa4 UARUYY] CSTATE_TMR: netidb=Fa4, linestate: Y
*May 27 15:23:40.035: [IDB Fa4 UARUYY] LSTATE_REQ: Entry
*May 27 15:23:40.035: [IDB Fa4 UARUYY] LSTATE_REQ: timers not running
*May 27 15:23:40.035: [IDB Fa4 UARUYY] LSTATE_REQ: starting lineproto timer
*May 27 15:23:40.035: [IDB Fa4 UARUYY] LSTATE_REQ: Exit
*May 27 15:23:40.035: [IDB Fa4 UARUYY] CSTATE_TMR: transition detected
*May 27 15:23:40.035: %LINK-3-UPDOWN: Interface FastEthernet4, changed state to up
*May 27 15:23:40.035: [IDB Fa4 UARUYY] TRANS_ADJ: Entry
*May 27 15:23:40.035: [IDB Fa4 UARUYY] TRANS_ADJ: Exit
*May 27 15:23:40.035: [IDB Fa4 UARUYY] CSTATE_TMR: Exit
*May 27 15:23:41.035: [IDB Fa4 UARUYY] LSTATE_TMR: Entry
*May 27 15:23:41.035: [IDB Fa4 UARUYY] LSTATE_TMR: not spoofing, current state: Y
*May 27 15:23:41.035: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4, changed state to up
*May 27 15:23:41.035: [IDB Fa4 UARUYY] LSTATE_TMR: informing line state transitions
*May 27 15:23:41.035: [IDB Fa4 UARUYY] TRANS_ADJ: Entry
*May 27 15:23:41.035: [IDB Fa4 UARUYY] TRANS_ADJ: Exit
*May 27 15:23:41.035: [IDB Fa4 UARUYY] ROUTE_ADJ: Entry
*May 27 15:23:41.035: [IDB Fa4 UARUYY] ROUTE_ADJ: Exit
*May 27 15:23:41.035: [IDB Fa4 UARUYY] LSTATE_TMR: Exit
*May 27 15:23:45.299: [IDB Fa4 UARUYY] LSTATE_REQ: Entry
*May 27 15:23:45.299: [IDB Fa4 UARUYY] LSTATE_REQ: timers not running
*May 27 15:23:45.299: [IDB Fa4 UARUYY] LSTATE_REQ: starting lineproto timer
*May 27 15:23:45.299: [IDB Fa4 UARUYY] LSTATE_REQ: Exit
*May 27 15:23:45.299: [IDB Fa4 UARUYY] CSTATE_REQ: Entry, requested state: D
*May 27 15:23:45.299: [IDB Fa4 UARUYY] CSTATE_REQ: starting ctimer (2000)
*May 27 15:23:45.299: [IDB Fa4 DURUYY] CSTATE_REQ: state assign
*May 27 15:23:45.299: [IDB Fa4 DURUYY] LSTATE_REQ: Entry
*May 27 15:23:45.299: [IDB Fa4 DURUYY] LSTATE_REQ: Exit
*May 27 15:23:45.299: [IDB Fa4 DURUYY] CSTATE_REQ: Exit
*May 27 15:23:46.299: [IDB Fa4 DURUYY] LSTATE_TMR: Entry
*May 27 15:23:46.299: [IDB Fa4 DURUYY] LSTATE_TMR: not spoofing, current state: n
*May 27 15:23:46.299: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet4, changed state to down
*May 27 15:23:46.299: [IDB Fa4 DURUYY] LSTATE_TMR: Exit
*May 27 15:23:47.299: [IDB Fa4 DURUYY] CSTATE_TMR: Entry
*May 27 15:23:47.299: [IDB Fa4 DURUYY] CSTATE_TMR: netidb=Fa4, linestate: n
*May 27 15:23:47.299: [IDB Fa4 DURUYY] LSTATE_REQ: Entry
*May 27 15:23:47.299: [IDB Fa4 DURUYY] LSTATE_REQ: timers not running
*May 27 15:23:47.299: [IDB Fa4 DURUYY] LSTATE_REQ: Exit
*May 27 15:23:47.299: [IDB Fa4 DURUYY] CSTATE_TMR: transition detected
*May 27 15:23:47.299: %LINK-3-UPDOWN: Interface FastEthernet4, changed state to down
*May 27 15:23:47.299: [IDB Fa4 DURUnY] TRANS_ADJ: Entry
*May 27 15:23:47.299: [IDB Fa4 DURUnn] TRANS_ADJ: propagating change to subifs
*May 27 15:23:47.299: [IDB Fa4 DURUnn] TRANS_ADJ: Exit
*May 27 15:23:47.299: [IDB Fa4 DURUnn] CSTATE_TMR: Exit
*May 27 15:23:55.299: [IDB Fa4 DURUnn] CSTATE_REQ: Entry, requested state: D
*May 27 15:23:55.299: [IDB Fa4 DURUnn] CSTATE_REQ: starting ctimer (2000)
*May 27 15:23:55.299: [IDB Fa4 DDRUnn] CSTATE_REQ: state assign
*May 27 15:23:55.299: [IDB Fa4 DDRUnn] LSTATE_REQ: Entry
*May 27 15:23:55.299: [IDB Fa4 DDRUnn] LSTATE_REQ: Exit
*May 27 15:23:55.299: [IDB Fa4 DDRUnn] CSTATE_REQ: Exit
*May 27 15:23:57.299: [IDB Fa4 DDRUnn] CSTATE_TMR: Entry
*May 27 15:23:57.299: [IDB Fa4 DDRUnn] CSTATE_TMR: netidb=Fa4, linestate: n
*May 27 15:23:57.299: [IDB Fa4 DDRUnn] CSTATE_TMR: starting lineproto timer
*May 27 15:23:57.299: [IDB Fa4 DDRUnn] CSTATE_TMR: Exit
*May 27 15:23:58.299: [IDB Fa4 DDRUnn] LSTATE_TMR: Entry
*May 27 15:23:58.299: [IDB Fa4 DDRUnn] LSTATE_TMR: not spoofing, current state: n
*May 27 15:23:58.299: [IDB Fa4 DDRUnn] LSTATE_TMR: informing line state transitions
*May 27 15:23:58.299: [IDB Fa4 DDRUnn] TRANS_ADJ: Entry
*May 27 15:23:58.299: [IDB Fa4 DDRUnn] TRANS_ADJ: Exit
*May 27 15:23:58.299: [IDB Fa4 DDRUnn] ROUTE_ADJ: Entry
*May 27 15:23:58.299: [IDB Fa4 DDRUnn] ROUTE_ADJ: Exit
*May 27 15:23:58.299: [IDB Fa4 DDRUnn] LSTATE_TMR: Exit
05-27-2015 07:10 PM
Did you try forcing the interface to stay up? I have used this for random remote management corner case issues on 2811s where loopbacks were not permitted. I am not completely sure if this command will be accepted on the 881 platform. Still worth a shot.
no autostate
05-28-2015 10:52 AM
no autostate is not an available command on int F4 on this 881. It is available on int Vlan1 though but no change after applying it on Vlan1.
