887 VDSL not synching Need help:
PATRICK DUPONT
Hello All,
I have configured the "ISP" part of the VDSL as i am a tech for the ISP that has access to this, but i am not able to get my 887V  to synch is there something i am doing wrng within the Cisco, i have included a debug and couple more things .. just have no clue why this is not working.
Thank You Pat
887V#sh debugging
VDSL 0 daemon:
  VDSL daemon error condition debugging is on
  VDSL daemon interface function debugging is on
  VDSL daemon state machine debugging is on
VDSL VDSL 0 ipc:
  VDSL IPC error debugging is on
  VDSL IPC Rx debugging is on
  VDSL IPC Tx debugging is on
VDSL VDSL 0 mbx:
  VDSL mailbox error debugging is on
  VDSL mailbox Rx debugging is on
  VDSL mailbox Tx debugging is on
VDSL 0 training log:
  VDSL training log is on
*Feb 16 17:24:07.259: VDSL 0: vdsl line state : discovery
*Feb 16 17:24:07.259: VDSL 0: SM_LINE_TRAIN boolean event
*Feb 16 17:24:07.259:     vdsl_daemon_sm VDSL 0: during state training, got event 17(line_training)
*Feb 16 17:24:07.259: @@@ vdsl_daemon_sm VDSL 0: training -> training
*Feb 16 17:24:13.271: ipc VDSL 0: vdsl_notif_interrupt, Sending LINE_STATE to VDSL Daemon, state = 7
*Feb 16 17:24:13.271: VDSL 0: vdsl line state : fullinit
*Feb 16 17:24:15.299: VDSL 0: SM_LINE_DOWN boolean event
*Feb 16 17:24:20.019: mbx VDSL 0: vdsl_msg_rcv_isr, Desc@ 604 : hdr= E004, total len= 28, msg len= 28, @618
*Feb 16 17:24:20.019: mbx VDSL 0: vdsl_msg_rcv_isr, Notification msg type 4, len= 28
*Feb 16 17:24:20.019: mbx VDSL 0: vdsl_process_msg_rcv, First message (1) : addr= 0x618, dest= 0x0xEE010E0, len= 28 00x 04x 11x 02x 00x 127x 00x 127x 00x 64x 4294967201x 4294967184x 00x 00x 00x 00x 42x
*Feb 16 17:24:20.023:  4294967243x 4294967204x 4294967280x 00x 00x 00x 00x 00x 00x 00x 00x
*Feb 16 17:24:20.023: mbx VDSL 0: vdsl_process_msg_rcv, Last message (2) : addr= 0x618, dest= 0xEE010FC, len= 28
*Feb 16 17:24:20.023: mbx VDSL 0: vdsl_msg_rcv_complete, call msg 4 rx handler, err= 0, len= 28, 0xEE010E0
*Feb 16 17:24:50.059: mbx VDSL 0: vdsl_msg_rcv_isr, Desc@ 60E : hdr= E004, total len= 28, msg len= 28, @618
*Feb 16 17:24:50.059: mbx VDSL 0: vdsl_msg_rcv_isr, Notification msg type 4, len= 28
*Feb 16 17:24:50.059: mbx VDSL 0: vdsl_process_msg_rcv, First message (1) : addr= 0x618, dest= 0x0xEE010E0, len= 28 00x 04x 11x 02x 00x 127x 00x 127x 00x 64x 4294967201x 4294967184x 00x 00x 00x 00x 42x
*Feb 16 17:24:50.059:  4294967243x 4294967204x 4294967280x 00x 00x 00x 00x 00x 00x 00x 00x
*Feb 16 17:24:50.059: mbx VDSL 0: vdsl_process_msg_rcv, Last message (2) : addr= 0x618, dest= 0xEE010FC, len= 28
*Feb 16 17:24:50.059: mbx VDSL 0: vdsl_msg_rcv_complete, call msg 4 rx handler, err= 0, len= 28, 0xEE010E0
*Feb 16 17:24:55.307: ipc VDSL 0: vdsl_notif_interrupt, Sending LINE_STATE to VDSL Daemon, state = 8
887V#sh controllers vdsL 0
Controller VDSL 0 is DOWN
Daemon Status:           Establishing Link
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'IKNS'
Chip Vendor Specific:   0x0000                   0x0100
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   'IKNS'
Modem Vendor Specific:  0x4602                   0x0100
Modem Vendor Country:   0xB500                   0xB500
Serial Number Near:    FHK1415724TCISCO731141205
Serial Number Far:
Modem Version Near:    15.0(1)M
Modem Version Far:     0x0100
Modem Status:            Idle
DSL Config Mode:         AUTO
Trained Mode:
TC Mode:                 PTM
DELT configuration:      enabled
DELT state:              in progress
Trellis:                 OFF                      OFF
Full inits:             0
Failed full inits:      0
Short inits:            0
Failed short inits:     0
Firmware        Source          File Name (version)
VDSL            user config     flash:vdsl.bin.A2pv6C016a1.d22e.IOS1501M1 (10)
Modem FW  Version:      100204_1318-4.02L.01.A2pv6C016a1.d22e0
Modem PHY Version:      A2pv6C016a1.d22e0
Training Log :  Started
Training Log Filename : flash:vdsllog.bin
887V#show diag 0
Slot 0:
        C887VDSL2 Mainboard Port adapter, 6 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Chassis MAC Address      : 68ef.bd69.512e
        PCB Serial Number        : FO6140901M7
        Hardware Revision        : 1.0
        Processor type           : B4
        Part Number              : 73-11412-05
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 04
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        MAC Address block size   : 14
        Chassis Serial Number    : FHK1415724T
        Product (FRU) Number     : CISCO887V-K9
        Version Identifier       : V01
        Radio Country Code       : FFFF
        Top Assy. Part Number    : 800-31524-01
        CLEI Code                : VAMLE10CRA
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C3 06 68 EF BD 69 51 2E C1 8B 46 4F 36 31
          0x10: 34 30 39 30 31 4D 37 40 06 4D 41 01 00 09 B4 82
          0x20: 49 2C 94 05 42 41 30 88 00 00 00 00 02 04 03 00
          0x30: 81 00 00 00 00 04 00 43 00 0E C2 8B 46 48 4B 31
          0x40: 34 31 35 37 32 34 54 CB 92 43 49 53 43 4F 38 38
          0x50: 37 56 2D 4B 39 20 20 20 20 20 20 89 56 30 31 20
          0x60: D9 03 40 C1 C2 4A FF FF C0 46 03 20 00 7B 24 01
          0x70: C6 8A 56 41 4D 4C 45 31 30 43 52 41 FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
887V#
Giuseppe Larosa
Hello Pat,
have you got a different VDSL modem that is able to synchronize?
VDSL performances are influenced by line conditions, the line may be too bad for it or there is a problem of interoperability with CO.
you should contact who is providing the VDSL service ( it not clear if it is a different company or a different group in your company)
Hope to help
Giuseppe
Hello Giuseppe,
have you got a different VDSL modem that is able to synchronize?----> No I Do not.
VDSL performances are influenced by line conditions, the line may be too bad for it or there is a problem of interoperability with CO.-----> This is fine i am les then .5km from the remote Co with VDSL E.Q
you should contact who is providing the VDSL service ( it not clear if it is a different company or a different group in your company)---->This is within the company i work in,so all the stasts for the LINE are fine.. i even brought my Router to the D-mark outside to see is it worked No luck..
This si how the ISP side is Configured for VDSL:
PTM encap = 64-65
Upbo = auto
band plan 998
U0 Band a-25-183
line code vdsl2
region = annex A
profile  p12a
trellis encoding and bit swapping are on.
card is a stigner VDSL2-IK-GEB
So th Question remains, does the Cisco 887VDSL need to have configuration with in the cisco for it Synch up???
Anybody have an answer to this by any chance.. ?
