887va Router Configuration problem over pppoe ADSL Movistar
pablo
I can't access internet through the router
atm0, atm0.1 and Dialer0 are UP and a dynamic IP addresss are assigned by the ISP
The atm interfaces show incoming and outgoing packets
I can ping the Public IP address from LAN
When I ping from outside then lan to the public IP address it don't reply.
I'm trying to configure the router with this lines:
! Last configuration change at 10:09:28 UTC Mon Dec 10 2012
! NVRAM config last updated at 10:09:33 UTC Mon Dec 10 2012
version 15.1
no service pad
service tcp-keepalives-in
service timestamps debug datetime
service timestamps log datetime
hostname RSantiga
boot-start-marker
boot system flash
boot-end-marker
logging buffered 8192
enable secret 5 $1$Xaob$OvVVWfDrGm97K49fntQYG1
enable password Coa000740.1
no aaa new-model
memory-size iomem 10
no ip source-route
no ip routing
no ip cef
no ip bootp server
no ip domain lookup
no ipv6 cef
vpdn enable
vpdn-group pppoe
license udi pid CISCO887VA-SEC-K9 sn FCZ1641C7PJ
controller VDSL 0
interface Ethernet0
no ip address
no ip route-cache
shutdown
no fair-queue
interface ATM0
description ADSL
no ip address
no ip route-cache
no atm ilmi-keepalive
hold-queue 224 in
bundle enable
interface ATM0.1 point-to-point
no ip route-cache
pvc 8/32
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface Vlan1
ip address 100.100.100.250 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
ip virtual-reassembly in
no ip route-cache
hold-queue 100 out
interface Dialer0
ip address negotiated
no ip redirects
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication pap callin
ppp pap sent-username adslppp@telefonicanetpa password 0 adslppp
ppp ipcp route default
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat translation tcp-timeout 900
ip nat translation udp-timeout 15
ip nat translation dns-timeout 10
ip nat translation icmp-timeout 10
ip nat inside source list 120 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 120 permit ip 100.100.100.0 0.0.0.255 any
no cdp run
control-plane
line con 0
line aux 0
line vty 0 4
password Coa000740.2
login
transport input all
scheduler max-task-time 5000
end
cadet alain
reenable ip routing:
config t
ip routing
Regards.
Alain
cadet alain
config t
ip routing
Regards.
Alain
pablo
Thank you so much!!
Very helpful
