887va VDSL2 with public static /29 net and 2 vlans
ilRobby
Hi!
I've a working config that allow internet traffic trought a firewall that is direct connected to 887 fa3 (vlan2 - public ip).
Now I would to connect a "guest" wireless network that has to bypass firewall; I've connected the eth of the access point to fa0 (vlan 3), but i can't reach internet from wireless clients...
My goal is natting vlan3 clients with the ip of router (vlan2), but, at the same time, router must not apply nat on the connections starts from the firewall..
Can anyone help me to achieve this configuration?
I've attached the running conf.
Many thanks,
Roberto
10 Replies 10
ilRobby
Nobody because the question is stupid or technically impossible on a isr router?
basically, NAT only applies to what you specify. So the below should work (changes marked in bold). However, since you have two public IP addresses on the outside, I am not sure that traffic from VLAN 3 gets routed properly, since you only have a default route out Dialer 1.
Either way, if the below doesn't work for you, we need to implement to VRFs.
version 15.1
service nagle
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname vRouter
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
clock timezone GMT 1 0
clock summer-time summertime recurring last Sun Mar 3:00 last Sun Oct 3:00
ip source-route
no ip dhcp use vrf connected
ip dhcp binding cleanup interval 600
ip cef
ip domain name acme.priv
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip multicast-routing
no ipv6 cef
no vlan accounting
license udi pid CISCO887VA-SEC-K9
controller VDSL 0
operating mode vdsl2
ip tftp source-interface Vlan2
ip ssh time-out 30
ip ssh rsa keypair-name MY_KEYS
ip ssh logging events
ip ssh version 2
ip ssh stricthostkeycheck
interface Ethernet0
no ip address
interface Ethernet0.2
encapsulation dot1Q 2
pppoe-client dial-pool-number 1
interface ATM0
mtu 1492
no ip address
shutdown
no atm ilmi-keepalive
hold-queue 224 in
interface FastEthernet0
switchport access vlan 3
no ip address
interface FastEthernet1
interface FastEthernet2
no ip address
interface FastEthernet3
switchport access vlan 2
no ip address
interface Vlan1
no ip address
interface Vlan2
description vlan2 Lax_EXT (public)
ip address 83.xxx.xxx.249 255.255.255.248
ip nat outside
ip virtual-reassembly in
interface Vlan3
description LAN MNG
ip address 172.16.2.1 255.255.255.192
ip nat inside
interface Dialer0
mtu 1492
ip address negotiated
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp chap hostname xxx
ppp chap password 7 xxxx
ppp pap sent-username xxxx
no cdp enable
no ip classless
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Vlan2 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 permanent
ip route 83.xxx.xxx.250 255.255.255.255 83.xxx.xxx.254 permanent
ip route 83.xxx.xxx.251 255.255.255.255 83.xxx.xxx.254 permanent
access-list 1 permit 172.16.2.0 0.0.63
access-list 101 permit ip 83.211.183.248 0.0.0.7 any
access-list 102 permit ip 172.16.2.0 0.0.0.63 any
dialer-list 1 protocol ip permit
control-plane
banner login ^CC
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 0 0
login local
transport input ssh
end
Hi Georg,
thanks for your reply!
I've tried your suggestion but still not working..!
From a win10 wireless client I can't ping the vlan2 ip nor 8.8.8.8, but I can succesfully ping vlan3
If I start "debug icmp" I can see only the packets to vlan3
With no active (visible) connections from wireless client (ssh session active, tcp 22), if I start "debug ip nat 1 detailed" router shows a lot of this messages:
000494: May 12 19:32:14.514 summert: NAT - SYSTEM PORT for 83.211.183.249: allocated port 0, refcount 5971, localport 4294967295, localaddr 0.0.0.0, flags 1, syscount 5971, proto 6
If I start "debug ip tcp packet address 172.16.2.9" (wireless client) router shows only the ssh connection to vlan3 ip.
From the router I succesfully ping internet name/address
I'm quite noobie in routing/swithcing, I don't know vrf!
Can you help me please?
Bye,
Roberto
post the configuration you currently have, I just want to check if you haven't missed something...;)
looking at your original post again, I just want to make sure that I understand your physical setup:
Your router has a connection to the firewall on FastEthernet3 (VLAN2).
Your wirless clients are connected to FastEthernet0 (VLAN 3).
You have a separate direct link to the Internet through Ethernet0.2 (Dialer 0).
Maybe you can post a brief schematic drawing of your physical setup...
Hello Georg,
this is the running conf with your suggestions:
version 15.1
service nagle
no service pad
hostname vRouter
boot-start-marker
boot-end-marker
enable password 7 012714144C0F565E73
no aaa new-model
ip source-route
ip cef
ip domain name Mindless.priv
no ipv6 cef
no vlan accounting
license udi pid CISCO887VA-SEC-K9 sn FCZ163292GS
username ************ secret ***********************
controller VDSL 0
ip ssh time-out 30
ip ssh rsa keypair-name SSH_MYKEYS
ip ssh version 2
interface Ethernet0
 no ip address
interface ATM0
 mtu 1492
 no ip address
 shutdown
 hold-queue 224 in
 no ip address
 no ip address
 no ip address
 no ip address
interface Vlan1
 no ip address
interface Vlan2
 ip nat outside
interface Vlan3
 description LAN MNG
 ip nat inside
interface Dialer0
 mtu 1492
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp chap hostname ****************
 ppp chap password 7 *************
 ppp pap sent-username *******************
 no cdp enable
no ip classless
no ip http server
access-list 1 permit 172.16.2.0 0.0.0.63
control-plane
banner login ^CC
^C
line con 0
 no modem enable
line aux 0
line vty 0 4
 access-class vtyacl_SSH_Access in
 exec-timeout 0 0
 login local
 rotary 1
 transport input ssh
And in the attachment a small schema.
Tell me if something is unclear!
Thanks again,
Roberto
this is from your original post:
My goal is natting vlan3 clients with the ip of router (vlan2), but, at the same time, router must not apply nat on the connections starts from the firewall...
Sorry for the confusion, I don't understand what you are asking. If you want wireless clients from VLAN 3 to get to the Internet, you need to change the NAT statement to:
ip nat inside source list 1 interface Dialer0 overload
VLAN 2 has a public IP address, what addresses do the clients in VLAN 2 have ?
I will try and reply you in about 30'!
 There's no client on vlan2, firewall nat anything with the 2 public ips for which I did the static route to logic ip of cluster fw!
if I nat on the dialer, I will nat also the vlan2 connections with the router ip? I would not want this...
Sorry for the misunderstanding. I am lost. Which inside IP addresses is VLAN 2 supposed to NAT ? Put the IP source and destinations in your drawing as well, that might clear things up...
It works Georg!
I'm writing you from the wireless client!
I've to add also "ip nat outside" on di0.
Now client has the pubblic address of the di0
All original lan sources behind firewalls are on B class 172.16, except "all" 172.16.2.0/24; for each lan, firewall (the active node) is the default gw and, if the destination is internet, fw nats the sources with one of the 2 static pubblic address of vlan2 subnet for which I did the static routes.
