891 router slows down my internet speed more than a quater of the isp given speed
winfulmatts
hello folks,
i recently configured an 891 router for a client and it worked very well, but less than 90 days, i got a call from the client that the internet speed has greatly reduced, i went there and it was true.
i decided to isolate the isp ONT box from the infrastructure, i tested the speed of the internet direct and it was very fast and the same value with what the isp provides, i used a different router (fortigate) and it worked very fine with the same speed given by the isp, i connected the network infrastructure with the fortigate router and the internet was very fine and all the users were happy.
i decided to reset the router and re configured it again but as soon as i connected it back to the network, the speed reduced again more than quater of the speed supplied by the ISP, so it became obvious that the fault is from the router.
this are the parameters i configured:
PPPOE on a dialer interface, added to the GI0/0 int
SVI for the L2 switched ports so that i could assign ip address to it
dhcp to give the host ip address
no security because i was using the fortigate firewall
is there anything i am oversighting or it is just the router that is bad?
suggestions please.
10 Replies 10
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Cisco recommends the 890 series for up to 15 Mbps of WAN bandwidth.  How much bandwidth is this ISP connection?
the ISP connection is actually 15.6mbps
Disclaimer
Posting
"15.6"; .6, that's seems a little unusual.  However, according to Cisco's recommendation, an 890 should be able to deal with that much bandwidth.
The WAN connection is 15.6 Mbps, symmetrical?  Handoff media is?  Handoff bandwidth is?
What's the CPU stats look like when you're unable to get the full 15.6 Mbps?
What's the interface stats look like, also when router is unable to support the 15.6 Mbps?
Are you able to post you config?
What IOS image are you running?
i have attached the router config, in txt format.
thanks
Disclaimer
Posting
I think you're doing PPPoE, and if so, I believe it will fragment full size packets.  You might gain some benefit by using ip tcp adjust-mss 1452.
what will be the impact of this command
Disclaimer
Posting
http://www.cisco.com/c/en/us/td/docs/ios/12_2sb/12_2sba/feature/guide/sb_admss.pdf
vik
What features are turned on? Can you paste your complete config?
i am not disposed to the router now, because i have not gone to the customer's site for the now, i will paste it as soon as i can.
i have attached the router config in txt format.
thanks
