892 and Catalyst 2960 extend LAN over sfp fiber
jeff
I need to extend the LAN on the 892 to the Catalyst switch via the fiber sfp modules in each unit.  I enabled the GigabitEthernet0 port on the 892 and set the medi-type to sfp.  What do I need to do to make that port part of the inside network?
I will post configs of both devices if neccesary; I guess I was hoping it would just plug and play!
Thanks!
5 Replies 5
Robert Falconer
Yes, post the configs please.
Router config below - it appears that the SFP slot on the 892 is for WAN only?  If I try to set switchport mode access on that port, it gives invalid command.
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
dns-server nnn.nnn.nnn.nnn nnn.nnn.nnn.nnn
lease 0 2
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
ip address nnn.nnn.nnn.nnn 255.255.255.252
ip access-group 101 in
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0
no ip address
duplex half
speed 100
media-type sfp
interface Vlan1
description $ETH_LAN$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 199 interface FastEthernet8 overload
ip route 0.0.0.0 0.0.0.0 nnn.nnn.nnn.nnn
access-list 101 permit tcp any any established
access-list 199 permit ip any any
Does the command "switchport" work to enable it for layer 2? What is the show interface details for that interface? 892 is a router correct? A router doesn't carry vlans.
What are you trying to accomplish? Router on a stick?
I am able to use the switchport command on the other interfaces (Fa0-7), but not on Gi0.  The 892 is a combination router/switch among other things.  I'm trying to use the sfp port which I have inserted a fiber connector to extend the LAN to a switch in a remote location.  Is there another way to use the Gi0 interface to pass traffic other than switchport?
I am going to say, just from reading the product details, that the Gi interface is WAN only which means you need to route your traffic. This would make sense since its a SOHO type router/switch.
