900 ISR L2TP VPN connection setup
T0mTheCat
i am trying to create a L2TP VPN connection for user to remote connection back to office.
can i set ip unnumbered GigabitEthernet5 ?
can I set in this way? or I have to create the loopback?
i am not sure which ip route i should create.
please advise.
much appreciated!
Building configuration...
Current configuration : 4712 bytes
! Last configuration change at 12:36:11 UTC Thu May 27 2021 by admin
version 15.8
service timestamps debug datetime msec localtime
service timestamps log datetime localtime
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$ZdLb$ZJXeo6.uhSrH0xzzwGsV..
aaa new-model
aaa authentication login avitavpn local
aaa authentication ppp VPDN_AUTH local
aaa authorization network default local
aaa authorization network avitanet local
aaa session-id common
memory-size iomem 25
clock timezone UTC 8 0
ip dhcp excluded-address 192.168.2.1 192.168.2.50
ip dhcp excluded-address 192.168.2.98 192.168.2.101
ip dhcp pool pool1
import all
network 192.168.2.0 255.255.255.0
dns-server 165.21.83.88 165.21.100.88 8.8.8.8
default-router 192.168.2.1
ip domain lookup source-interface GigabitEthernet5
ip domain name avitasg.webhop.org
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip ddns update method dyndns
HTTP
add https://xxx@members.dyndns.org/v3/update?hostname=avitasg.webhop.org&myip=192.168.2.1
interval minimum 0 12 0 0
ip cef
no ipv6 cef
vpdn enable
vpdn-group g-l2tp
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
license udi pid C921-4P sn xxx
license accept end user agreement
license boot module c900 technology-package securityk9
username admin secret 5 $1$H.hT$XUDCemW8m6XcAz5ofvJFx/
username avita password 0 xxx
redundancy
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key xxx address 0.0.0.0
crypto ipsec transform-set L2TP-Set2 esp-3des esp-md5-hmac
mode transport
crypto dynamic-map avita 1
set nat demux
set transform-set avita
crypto map outside_map 65535 ipsec-isakmp dynamic avita
interface GigabitEthernet0
switchport access vlan 250
switchport mode access
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
shutdown
duplex auto
speed auto
ip ddns update hostname avitasg.webhop.org
ip ddns update dyndns
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Virtual-Template1
peer default ip address pool l2tp-pool
ppp authentication ms-chap-v2 VPDN_AUTH
interface Vlan1
no ip address
interface Vlan250
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip local pool l2tp-pool 10.10.10.10 10.10.10.15
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 1 interface GigabitEthernet5 overload
ip nat inside source static tcp 192.168.2.200 9999 interface GigabitEthernet5 9999
ip nat inside source static tcp 192.168.2.200 81 interface GigabitEthernet5 81
ip nat inside source static tcp 192.168.2.200 8000 interface GigabitEthernet5 8000
ip nat inside source static tcp 192.168.2.99 445 interface GigabitEthernet5 445
ip nat inside source static udp 192.168.2.99 137 interface GigabitEthernet5 137
ip nat inside source static udp 192.168.2.99 138 interface GigabitEthernet5 138
ip nat inside source static tcp 192.168.2.99 139 interface GigabitEthernet5 139
ip nat inside source static tcp 192.168.2.99 465 interface GigabitEthernet5 465
ip nat inside source static tcp 192.168.2.61 3389 interface GigabitEthernet5 3389
ip nat inside source static udp 192.168.2.99 1701 interface GigabitEthernet5 1701
ip nat inside source static udp 192.168.2.99 500 interface GigabitEthernet5 500
ip nat inside source static udp 192.168.2.99 4500 interface GigabitEthernet5 4500
ip nat inside source static udp 192.168.2.99 1194 interface GigabitEthernet5 1194
ip nat inside source static tcp 192.168.2.99 137 interface GigabitEthernet5 137
ip nat inside source static tcp 192.168.2.99 138 interface GigabitEthernet5 138
ip nat inside source static tcp 192.168.2.99 5001 interface GigabitEthernet5 5001
ip route 0.0.0.0 0.0.0.0 GigabitEthernet5
ip route 0.0.0.0 0.0.0.0 GigabitEthernet5 dhcp
snmp-server group snmpv3grp v3 auth
access-list 1 permit 192.168.2.0 0.0.0.255
use the loopback. You don't need any routing, as IPCP will automatically add the route(s):
--> interface Loopback1
--> description VPN L2TP
--> ip address 192.168.2.100
Hi Georg!
Thank you for your reply!
I followed your command, however i got some question.
R1(config)#interface loopback1
R1(config-if)#desc
R1(config-if)#description VPN L2TP
R1(config-if)#ip address 192.168.2.15 255.255.255.0
% 192.168.2.0 overlaps with Vlan250
R1(config-if)#ip address 192.168.2.100
% Incomplete command.
If i use different ip address range will the remote device unable to detect local network?
Thank you.
