A BGP prefixes announcement question
Safar Safarov
Below is brief of bgp config on my router to ISP.
interface GigabitEthernet0/0
ip address 2.2.2.2 255.255.255.252 secondary
ip address 1.1.1.2 255.255.255.252
no ip redirects
no ip proxy-arp
router bgp 4444
no synchronization
bgp log-neighbor-changes
bgp bestpath compare-routerid
network 3.3.3.0 mask 255.255.240.0
neighbor BGP peer-group
neighbor BGP remote-as 5555
neighbor BGP version 4
neighbor BGP soft-reconfiguration inbound
neighbor BGP prefix-list BGP-to-ISP out
neighbor BGP route-map BGP-OUT out
neighbor 1.1.1.1 peer-group BGP
neighbor 1.1.1.1 description BGP-ISP-RR01
neighbor 2.2.2.1 peer-group BGP
neighbor 2.2.2.1 description BGP-ISP-RR02
no auto-summary
ip route 3.3.3.0 255.255.240.0 GigabitEthernet0/0
ip prefix-list BGP-to-ISP seq 5 permit 3.3.3.0/20 le 24
route-map BGP-OUT permit 10
match ip address prefix-list BGP-to-ISP
ISP announces 0.0.0.0/0 prefix to my router.
Can a loop occur if prefix announced by my router to ISP (i.e. 3.3.3.0/20) is inside of prefix announced by ISP to me (i.e. 0.0.0.0/0)?
Peter Paluch
Hello Safar,
You probably meant a different network: the 3.3.3.0/20 is not a valid network address. A netmask of /20 requires a multiple of 16 in the 3rd octet of the network address. In order for 3.3.3.0 to be a network address, the mask must be at least /24 and more.
To your question: No such loop should occur because a router always uses the longest matched prefix from its routing table to route packets. Even if your routing table contains both 3.3.3.0/X and 0.0.0.0/0, for all packets from within the network 3.3.3.0/X, the more specific route will be used. So in stable topology, no routing loops may occur.
A transient routing loop can occur when the 3.3.3.0/X route is removed from your routing table but the update has not yet been sent via BGP to your ISP. In that case, you are sending the packets for 3.3.3.0/X towards your ISP because of the default route, and the ISP is sending the packets back to you because it still has the 3.3.3.0/X route pointing to you. This is not a misconfiguration - it is caused by delays in propagating routing information, and is a routine problem with all routing protocols.
A possible workaround would be to have a static Null0 route configured for the same network with a higher administrative distance. If the correct 3.3.3.0/X network gets disconnected, it will be automatically replaced by this Null0 network, preventing routing loops (all packets will be discarded without being forwarded anywhere):
ip route 3.3.3.0 X.X.X.X Null0 254
There is one gotcha related to this config - the network will constantly be advertised to your ISP, as it will always be present in your routing table (just with different next hop - via Gi0/0 when everything's correct, or via Null0 if the real path fails). If you do not want this to happen and advertise the network to your ISP only when it is truly reachable, the config will be slightly more complex:
route-map Adv3.3.3.0 deny 10
match interface Null0
route-map Adv3.3.3.0 permit 20
router bgp 4444
network 3.3.3.0 mask 255.255.240.0 route-map Adv3.3.3.0
A couple of comments to your configuration, though:
  1. Your static route for the "network" 3.3.3.0/20 points directly to your Gi0/0 interface. This leads to excessive ARP traffic and excessively large ARP tables. You should rewrite the static route using the next hop IP address and avoid pointing directly to the egress interface.
  2. You are using the soft-reconfiguration inbound clause in your BGP configuration. This increases the memory footprint of your BGP process by storing both unfiltered and filtered BGP database. However, all current BGP implementations support the Route Refresh capability for graceful inbound policy changes, and using the soft-reconfiguration inbound is thereby completely unnecessary and even wrong. Please consider removing the command from your configuration.
Feel welcome to ask further.
Best regards,
Peter
Peter Paluch
Hello Safar,
router bgp 4444
Best regards,
Peter
peter , i was just about to echo ur words but u got this before me
Hi Kishore,
Oh, please do And please feel more than welcome to add any comments.
Best regards,
Peter
no . no more to add. you took this away from me ... heheh . You knw ur explanation is always a zillion times better than me.
