Security Zones with multiple inside NAT interfaces.
johnhart
Hi IOS Users,
I am having big problems trying to get what should be a rather simple configuration to work.
I have a Cisco 2901 Router and have setup Zone Based Firewall on this.
The machine has:
1 x EHWIC-4ESG
1 x HWIC-ADSL-M
1 x HWIC-2FE
I have configured it so that I have two private (NAT'ed IP networks)
<IOS>
interface fastethernet X/0
ip address 192.168.1.160 255.255.255.0
nat inside
zone-member security PRIVATE-ZONE
interface gigabitethernet X/0
ip address 192.168.223.1 255.255.255.0
nat inside
</IOS>
The outside NAT interfaces are on the ADSL line and 4ESG vlan interface.
I have also set up static routes so that all traffic destined for:
192.168.1.0/24 -> 192.168.1.1
192.168.223.0/24 -> 192.168.223.1
I would have thought that this would be a pretty simple setup as both the 192.168.x.0/24 address spaces are enrolled in the same zone and both are defined as being on the inside of the NAT, so therefore packet from 192.168.223.x machine destined to 192.168.1.x machines should be transparently accessible to each other, as by default if interfaces are in the same zone, than all traffic flows unchecked.
Unfortunately this is not the case....
Traffic from the 192.168.223.x network does not pass through to the 192.168.1.x network.
my traffic appears to disappear down the big bucket...
Interesting I can ping machine on 192.168.223.0/24 network from the 192.168.1.0/24
So the static routes setup on the router on the 192.168.1.0/24 appear to be routing ok.
The problem appears to be related to NAT/ZONE problem... any ideas?
John.
cadet alain
Can you post your sanitized config.
Regards.
Alain
Hi Cadet Alain,
here is a cut down version of the config.
As I am using CPP most of the stuff is pretty much bulk standard.
As per prior comments I have put both of the 192.168.x.0/255 address spaces into the PRIVATE-ZONE
As both the GigabitEthernet and FastEthernet interfaces are "inside" NAT and also in the same zone. I would expect all to be ok..
I have also looked the arp entries following doing PINGS and it shows entries for both IP addresses on the 192.168.1.0/24 network and the 192.168.223.0/24 network.
Could it be that the router is not routing the 192.168 address spaces as these are "non-routable" addresses?
Also I an ping 192.168.1.1 device but not the 192.168.1.136 device.
I can also do a "dig @192.168.1.1 www.google.com" and get an anwser, but I cannot do http to 192.168.1.1... so this is really puzzling. The 192.168.1.1 device is a Netgear VPN box, in which I have put static routes for 192.168.223.0/24 network.
! Last configuration change at 09:54:58 UTC Mon Jan 16 2012 by admin
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname big
boot-start-marker
boot-end-marker
ip dhcp excluded-address XX.XX.XX.1 XX.XX.XX.49
ip dhcp excluded-address XX.XX.XX.71 XX.XX.XX.254
ip dhcp excluded-address XX.XX.XX.71 XX.XX.XX.126
ip dhcp excluded-address 192.168.223.1 192.168.223.99
ip dhcp excluded-address 192.168.223.126 192.168.223.254
no ip bootp server
ip domain name DOG.com
ip name-server 139.XX.XX.XX
ip name-server 203.XX.XX.XX
ip inspect log drop-pkt
ip inspect audit-trail
ip inspect name CCP_MEDIUM appfw CCP_MEDIUM
redundancy
ip tcp synwait-time 10
no ip ftp passive
zone security dmz-zone
zone security in-zone
zone security out-zone
zone security PRIVATE-ZONE
interface Null0
no ip unreachables
interface GigabitEthernet0/0
description $ETH-LAN$
ip address 203.XX.XX.130 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
ip virtual-reassembly in
zone-member security in-zone
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
no mop enabled
interface FastEthernet0/2/0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
no mop enabled
interface FastEthernet0/2/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
duplex auto
speed auto
no mop enabled
interface ATM0/3/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0/3/0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface GigabitEthernet0/0/0
interface GigabitEthernet0/0/1
interface GigabitEthernet0/0/2
interface GigabitEthernet0/0/3
interface Vlan1
description $ETH-4ESG$$INTF-INFO-10/100/1000 Ethernet$$ETH-LAN$FW-DMZ$
ip address 203.XX.XX.1 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
zone-member security dmz-zone
interface Dialer0
description $FW_OUTSIDE$
ip address XX.XX.XX.XX 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname XXXXXX
ppp chap password 7 XXXXX
ppp pap sent-username XXXXXX password 7 XXXXXX
service-policy input sdmappfwp2p_CCP_MEDIUM
service-policy output sdmappfwp2p_CCP_MEDIUM
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip flow-top-talkers
top 200
sort-by bytes
cache-timeout 500
ip dns server
ip nat pool NAT-POOL1 203.XX.XX.161 203.XX.XX.189 netmask 255.255.255.224
ip nat inside source route-map SDM_RMAP_1 pool NAT-POOL1
ip route 0.0.0.0 0.0.0.0 165.XXX.XX.1
ip route 192.168.1.0 255.255.255.0 FastEthernet0/2/0 permanent
ip route 192.168.223.0 255.255.255.0 GigabitEthernet0/1 permanent
ip route 203.XX.XX.0 255.255.255.128 Vlan1 permanent
ip route 203.XX.XX.128 255.255.255.224 GigabitEthernet0/0 permanent
ip route 203.XX.XX.160 255.255.255.224 Loopback0 permanent
logging 203.XX.XX.XX
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.223.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip XXX.XXX.XXX.0 0.0.0.255 any
access-list 100 permit ip XX.XX.XX.0 0.0.0.255 any
access-list 102 remark CCP_ACL Category=2
access-list 102 permit ip 192.168.223.0 0.0.0.255 any
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 102
control-plane
ntp update-calendar
ntp server 192.189.54.17
ntp server 192.189.54.33
ntp server 203.161.12.165
ntp server 130.102.2.123
end
if everything is ok before the ZBF then it is not a L3 problem and RFC1918 addresses are not routeable on the internet only.
Is it normal you put your G0/0  interface which is outside NAT  as a member of inside zone ?
Can you add following command and try pinging again and post any log output: ip inspect log drop-pkt
There lacks also the class-maps and policy-maps along with corresponding ACLs for your ZBF config , could you post it please
Regards.
Alain
Cadet Alain,
luckly I have found the problem... and it was not to do with the CISCO IOS config...
It turned out that most of the machines on the 192.168.1.0/24 network were still configured with an address mask of 255.255.0.0 frrom before seperating the network into 2.
And that this in combination with some broadcast message was resulting on some requests getting forwarded from the machines to the 192.168.1.160 interface and from there it was trying to forward them via NAT, which was resulting in corrupted NAT transations tables....
Glad to have finally got this resolved.
Thanks.
John.
