07-21-2005 09:43 AM - edited 03-03-2019 10:06 AM
I have 3 cisco 1720 routers. I am running RIP and advertising all attached networks. I can ping all interfaces from all interfaces. I can get to any Host from network A to B and vice versa and from network A to C and vice versa but I cannot get from a host on network B to network C through A.
The 3 networks are connected via 2 T1 lines. Here are the configs. If you have any suggestions please let me know
User Access Verification
Password:
Router A>en
Password:
JCW#sh ru
Building configuration...
Current configuration : 1376 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router A
enable secret xxxx
memory-size iomem 25
ip subnet-zero
ip name-server 205.171.3.65
ip name-server 205.171.2.65
interface Tunnel1
no ip address
interface FastEthernet0
ip address 10.6.18.4 255.255.255.0
speed auto
interface Serial0
ip address 192.168.101.2 255.255.255.0
ip accounting output-packets
no fair-queue
service-module t1 clock source internal
service-module t1 timeslots 1-24
interface Serial1
ip address 192.168.100.4 255.255.255.0
no fair-queue
router rip
network 10.0.0.0
network 192.168.100.0
network 192.168.101.0
ip classless
ip forward-protocol udp 5631
ip forward-protocol udp 5632
ip route 0.0.0.0 0.0.0.0 10.6.18.2
ip http server
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 2 permit 10.6.18.0 0.0.0.255
access-list 3 permit 192.168.100.0 0.0.0.255
access-list 4 permit 192.168.1.0 0.0.0.255
access-list 5 permit 192.168.101.0 0.0.0.255
access-list 131 permit ip 192.168.101.0 0.0.0.255 10.6.18.0 0.0.0.255
arp 10.6.18.5 00c0.b607.d30b ARPA
line con 0
logging synchronous
line aux 0
line vty 0 4
session-timeout 60
login
Router C#sh ru
Current configuration : 1338 bytes
version 12.2
hostname Router C
ip subnet-zero
interface Tunnel1
no ip address
ip address 192.168.1.4 255.255.255.0
ip nat inside
speed auto
interface Serial0
ip address 192.168.100.1 255.255.255.0
ip nat outside
no fair-queue
router rip
network 192.168.1.0
ip nat inside source list 130 interface Serial0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 10.6.18.0 255.255.255.0 192.168.100.4
ip http server
access-list 121 permit ip 10.6.18.0 0.0.0.255 any
access-list 130 permit ip any host 10.6.18.5
access-list 133 permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
Router B#sh ru
Current configuration : 1123 bytes
version 12.2
ip subnet-zero
ip address 192.168.0.4 255.255.255.0
ip nat inside
speed auto
interface Serial0
ip address 192.168.101.1 255.255.255.0
ip nat outside
no fair-queue
router rip
network 192.168.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 192.168.1.0 255.255.255.0 192.168.100.1
ip http server
access-list 131 permit ip 10.6.18.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 133 permit ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
07-21-2005 12:30 PM
Hi Dale,
Could you please specify which subnet you are unable to access from where. At the same time just noticed you have a nat access-list 130 on your Routers B and C that point to the same host. Can you elaborate on what connectivity (from which ip to which ip, and how(pings, telnet etc)) you are trying to achieve.
07-22-2005 08:05 AM
vdadlaney,
Thanks for your response.
I am unable to get from a host on subnet 192.168.0.0 to a host on 192.168.1.0 I am, for whatever reason able to go from a host on 192.168.1.0 to a host on 192.168.0.0.
The other NAT, access-list 130, is because there is a non windows server on subnet 10.6.18.0 that absolutely will not work unless the addresses are NATed, THe route that a host would have to take from network .0.0 to .1.0 and vice versa would be:
192.168.0.4 fa0 int Router B
192.168.101.1 S0 int Router B
192.168.101.2 S0 int Router A
192.168.100.4 S1 int Router A
192.168.100.1 S0 int Router C
192.168.1.4 fao int Router C
I can ping from fa0 int on router B to the fa0 int on router C but when I tried to ping an inside host on Router C I got no response, when I did a traceroute from int fa0 on router B to a host on router C I hit the 192.168.101.2 int on Router A and it tossed it back to 192.168.101.1 on Router B where it failed the other 27 hops.
Let me know if you need any other info
Dale
07-25-2005 11:02 AM
Hi Dale,
Can you post the output of the ping and traceroute. Also it seems assuming that you are able to ping from Router B's ethernet to Router C's ethernet that routing appears to be correct. It doesn't look like from your config that the traffic is going to hit the NAT access-list and hence its not going to be natted unless u already have a nat entry from before. Can you also post a output of show ip nat translation. Finally check your hosts to see if they are correctly configured with the subnet mask, default gateway etc. HTH
Vikram
07-27-2005 09:26 AM
Sorry its taken so long to get back to you on this. Turns out it is certain hosts and 1 server in particular that I can't get to. I stripped the routers back down to bare bones, IP Address and RIP and I can get to most hosts. I had to put in the NAT command like the one for host 10.6.18.5 in order for it to work. I don't know what it is about some of these hosts not responding to anything outside there own subnet but the NATing seems to take care of it.
Thanks for your time again
Dale
