A noob configuring a Border (c2621)
Maharlican
Hi, I'm a student and I am trying to setup a Cisco 3 layer modeled Campus network. I'm so far done setting up the Cores, Distribs and Access' but I am stuck setting up the border. Can, please, anyone help me on this, by giving hints or atleast post a link of an article regarding my problem. Thank you.
configure interface fa 0/0 as follows:       ip address 192.168.*.* 255.255.255.0
     (use   the next available ip in 192.168.10 network)   (DONE)
configure interface fa0/1 as follows:
     ip address 155.13*.***.245 255.255.255.0 (DONE)
Configure OSPF routing protocol
     configure static route to send all trafic   through 155.135.55.245
Configure NAT (network address   translation) with the following info
     nat pool ip 155.13*.***.219
use the interface fa0/1 as the outbound   NAT address (PAT)
fa 0/0 will be uses as nat inside and   fa0/1 as nat outside
use various show command to see the   status of NAT
8 Replies 8
mvsheik123
Level 7
Level 7
1. Check this link for NAT configuration & Show coomands/ Troubleshooting for NAT:
http://www.cisco.com/en/US/partner/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
2.Static route: basic default route : ip route 0.0.0.0 0.0.0.0
3. OSPF:
This is based on your network requirement (subnets, area etc..).,.but basic configuration..
http://www.petri.co.il/how-to-configure-ospf-in-cisco-ios.htm
hth
MS
Thank you mvsheik123, but it seems that the first link is for special members only.
Attached is a screenshot of what I get when I type "router ospf 1"
am I missing anything?
The OSPF process can't start if there is no RID( router-id), and that's what the message is saying.
How is router-id derived:
-highest up/up loopback ip address
or
-highest up/up ip address of physical interface
or
- router-id command under router ospf process
Regards.
Alain.
You need at least one interface to be up/up in the "sh ip int brief" command for OSPF to start. Alternatively you can configure a loopback address on the border router and then OSPF would use this as it's router-id. Or you can specify a router-id specifically under the OSPF configuration.
It looks like none of your interfaces on the border router are up. Have you done eg.
int fa0/0
no shut
Edit - as for the URL link MS provided that you can't access, just remove the /partner/ bit from the URL and you will be able to get to the page.
Jon
It worked.. and thank you!
now I have to do this
     Configure OSPF routing protocol (DONE, I guess)
  •      configure static route to send all trafic   through 155.13x.xx.xx
will this do the trick?
route if_name dest_ip mask gateway_ip
[distance]
Example:
hostname(config)# route outside 10.10.10.0
255.255.255.0 192.168.1.1 [1]
This is the command for a PIX/ASA not a router, for a router the command is:
ip route dest_ip mask [gateway_ip or interface]
Configuring the OSPF process only without telling which route to advertise and on which interface to do neighbourship is useless so you'll have to:
-use the network ip_add inv_mask area area_id command
- or if you've got the IOS supporting it, in interface config use ip ospf pid area area_id
Regards.
alain.
cadet alain, so far here is what I did. tnx!
Maharlican
I think my given task is done. I noticed that the configuration can be done for 2-3 minutes and I did it for over a week.. lol
     configure static route to send all trafic   through 155.135.55.245 (DONE)
                     router ospf 1
                     network 192.168.0.0 0.0.255.255 area 0
Configure NAT (network address   translation) with the following info (DONE)
          ip nat pool name 155.13*.***.219 155.13*.***.219 netmask 255.255.255.0
use the interface fa0/1 as the outbound   NAT address (PAT)(DONE)
                      int fa0/0
           ip nat inside
           exit
           int fa0/1
           ip nat outside
           exit
use various show command to see the   status of NAT (DONE)
                    show ip nat statistics
          show ip nat translation
tnx for the help!!
