X.25 Record Boundary Preservation for Data Communications Networks
jcardozo
I am trying to setup RBP to the X.25 connections to be routed to a TCP port
I need connect by PAD (dialing) when the device connects it asks for the password of the router and does not open the TCP port.
Following is the set-up was made​​:
interface Serial1/0
 encapsulation x25 dce
 x25 address 12030
 x25 map rbp 12132 remote host 10.0.0.1 port 9999
I saw that the RBP only works on leased-line X.25
"X.25 connections will be supported over leased-line X.25 interfaces only."
I have the X.25 line but I do not know if is a leased-line
Can anyone help me?
paolo bevilacqua
X.25 is all leased lines. Or local connection, that is the same effect.
Thanks.You would tell why I Can not connect on TCP port ande why the router ask for the password ?
