A way lead Cisco Router become URL-based Router
Kagamigawa
  Usually, when we visit Internet websites, we use domain names to access them. However, DNS is an unreliable stateless protocol that is easily poisoned. To solve this problem, we now propose the following ideas and attach a tutorial.
things to prepare:
An IOS-XE based router as user gateway
A domain name service provider(include Dynamic dns registration service)
An external router on cloud (I used vyos on oracle cloud)
A Digital Signature Certificate
Copy the files I uploaded to bootflash(unzip , *.txt use update-*.sh create)
------basic configuration on router let local client access internet-----
!Cisco IOS Software [Fuji], Virtual XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.7, RELEASE SOFTWARE (fc1)
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
platform shell
hostname gateway
aaa new-model
aaa authentication login default local
aaa authorization exec default local
clock timezone GMT 8 0
ip gratuitous-arps
ip domain name home.local
ip host esxi1.home.local 192.168.0.10
ip host esxi2.home.local 192.168.0.11
ip host gateway.home.local 192.168.0.254
ip host switch.home.local 192.168.0.2
ip host vcsa.home.local 192.168.0.45
ip dhcp excluded-address 192.168.0.1 192.168.0.50
ip dhcp excluded-address 192.168.0.200 192.168.0.254
ip dhcp pool pat
 host 192.168.0.0 255.255.255.0
 dns-server 192.168.0.254
 default-router 192.168.0.254
login on-success log
spanning-tree mode rapid-pvst
username cisco privilege 15 password 'yuor password'
lldp run
cdp run
bridge irb
interface GigabitEthernet1
 description WAN
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface GigabitEthernet2
 ip address 192.168.0.254 255.255.255.0
 ip nat inside
 cdp enable
interface Dialer1
 description WAN
 bandwidth 'isp commit upload bandwidth'
 ip address negotiated
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 ppp pap sent-username 'your account' password 'your password'
 ppp ipcp dns request
 ppp ipcp route default
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list pat interface Dialer1 overload
ip dns server
ip access-list standard pat
 permit 192.168.0.0 0.0.255.255
kron occurrence backup at 23:59 recurring system-startup
 policy-list backup
kron policy-list backup
 cli sh run | redirect tftp://'tftp server address'/router.cfg
logging trap debugging
logging origin-id hostname
logging host 'logging server address'
snmp-server community 'your password' RO
snmp-server location 'your location'
snmp-server contact 'your contact way'
snmp-server enable traps
line vty 0 4
 access-class pat in
 logging synchronous
 transport input telnet
line vty 5 15
 exec-timeout 30 0
 logging synchronous
 transport input ssh
ntp master 1
ntp server cn.pool.ntp.org
end
------sslvpn configuration on router let remote client access resource-----
aaa authentication login sslvpn local
aaa authorization network sslvpn local
ip ddns update method oray
 HTTP
  add http://'your account':'your password'@'DNS provider domain'/ph/update?hostname='your domain'&&myip=
 interval maximum 0 0 1 0
 interval minimum 0 0 1 0
interface Dialer1
 ip ddns update hostname 'your dns domain name'
 ip ddns update 'dns provider name' host 'dns provider domain name'
crypto pki import VPN pkcs12 bootflash:'Digital Signature Certificate(.pfx)'.pfx password 'your password'
ip local pool sslvpn 192.168.0.200 192.168.0.253
crypto ssl proposal sslvpn-proposal
 protection rsa-3des-ede-sha1 rsa-rc4128-md5 rsa-aes128-sha1 rsa-aes256-sha1
crypto ssl authorization policy sslvpn-auth-policy
 pool sslvpn
 banner 'your banner'
 def-domain home.local
crypto ssl policy sslvpn-policy
 pki trustpoint VPN sign
 ip interface Dialer1 port 'custom port'
crypto ssl profile sslvpn-profile
 match policy sslvpn-policy
 aaa authentication user-pass list sslvpn
 aaa authorization group user-pass list sslvpn sslvpn-auth-policy
 aaa accounting user-pass list sslvpn
 authentication remote user-pass
 max-users 100
ip http secure-trustpoint VPN
------overlay configuration on router establish bgp peer with external router-----
crypto isakmp policy 10
 encr 3des
 hash md5
 authentication pre-share
 group 14
crypto isakmp key 'your password' address 0.0.0.0
crypto ipsec transform-set TS esp-3des esp-md5-hmac
 mode transport
crypto ipsec profile PR
 set transform-set TS
interface Tunnel0
 description this is a hub
 ip address 192.168.255.2 255.255.255.240
 no ip redirects
 ip mtu 1400
 ip nhrp network-id 1
 ip nhrp redirect
 ip tcp adjust-mss 1300
 cdp enable
 tunnel source Dialer1
 tunnel mode gre multipoint
 tunnel protection ipsec profile PR
route-map vyos permit 10
 set community no-advertise
router bgp 64512
 template peer-policy VPN
  route-reflector-client
  soft-reconfiguration inbound
  send-community both
 exit-peer-policy
 template peer-session VPN
  remote-as 64512
  update-source Tunnel0
 exit-peer-session
 bgp router-id 192.168.255.2
 bgp cluster-id 192.168.255.2
 bgp log-neighbor-changes
 bgp graceful-restart
 neighbor 192.168.255.5 inherit peer-session VPN
 address-family ipv4
  network 192.168.0.0
  neighbor 192.168.255.5 activate
  neighbor 192.168.255.5 inherit peer-policy VPN
  neighbor 192.168.255.5 route-map vyos in
 exit-address-family
------check dmvpn and bgp peer (update non-nation prefix)-----
gateway#show dmvpn
Interface: Tunnel0, IPv4 NHRP Details
Type:Hub, NHRP Peers:2,
 # Ent  Peer NBMA Addr Peer Tunnel Add State  UpDn Tm Attrb
     1 111.197.207.228   192.168.255.1    UP    1d17h     D
     1 129.159.34.241    192.168.255.5    UP 04:30:35    DN
gateway#show bgp ipv4 unicast summary
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
192.168.255.1   4        64512    2773    2782     4813    0    0 1d17h           2
192.168.255.5   4        64512     274     304     4813    0    0 04:30:45      945
------create a guestshell-----
interface VirtualPortGroup0
 bandwidth 1000000
 ip unnumbered GigabitEthernet2
 ip nat inside
ip route 192.168.0.15 255.255.255.255 VirtualPortGroup0
app-hosting appid guestshell
 app-vnic gateway0 virtualportgroup 0 guest-interface 0
  guest-ipaddress 192.168.0.15 netmask 255.255.255.0
 app-default-gateway 192.168.0.254 guest-interface 0
 name-server0 8.8.8.8
end
guestshell enable
------run guestshell command to create dns server-----
guestshell run sudo yum -y install bind-utils nano tree perl
guestshell run sudo mkdir -p /etc/chinadns
guestshell run sudo cp -rf /bootflash/chinadns /etc/chinadns/
guestshell run sudo cp -rf /bootflash/chinadns.json /etc/chinadns/
guestshell run sudo cp -rf /bootflash/update-gfwlist.sh /etc/chinadns/
guestshell run sudo cp -rf /bootflash/update-chnroute.sh /etc/chinadns/
guestshell run sudo cp -rf /bootflash/update-chnlist.sh /etc/chinadns/
guestshell run sudo cp -rf /bootflash/gfwuser.txt /etc/chinadns/
guestshell run sudo cp -rf /bootflash/gfwlist.txt /etc/chinadns/
guestshell run sudo cp -rf /bootflash/chnroute.txt /etc/chinadns/
guestshell run sudo cp -rf /bootflash/chnlist.txt /etc/chinadns/
guestshell run sudo cp -rf /bootflash/start.sh /etc/chinadns/
guestshell run sudo chmod -R 7777 /etc/chinadns/
guestshell run sudo cp -rf /bootflash/dns.service /usr/lib/systemd/system/
guestshell run sudo chmod 754 /usr/lib/systemd/system/dns.service
guestshell run sudo systemctl daemon-reload
guestshell run sudo systemctl enable dns.service --now
guestshell run sudo systemctl status dns
------point to dns -------
ip dhcp pool macbook-m1
 host 192.168.0.77 255.255.255.0
 client-identifier 01c4.910c.aba6.4d
 dns-server 192.168.0.15
 dns 192.168.0.15
----------extenal router configuration---------
interfaces {
    ethernet eth0 {
        address dhcp
    loopback lo {
    tunnel tun0 {
        address 192.168.255.5/28
        encapsulation gre
        multicast enable
        parameters {
            ip {
        source-interface eth0
nat {
    source {
        rule 10 {
            outbound-interface eth0
            source {
                address 192.168.0.0/16
            translation {
                address masquerade
protocols {
    bgp 64512 {
        address-family {
            ipv4-unicast {
                network 2.0.0.0/8 {
                .......non-nation route.......
        neighbor 192.168.255.2 {
            address-family {
                ipv4-unicast {
                    soft-reconfiguration {
                        inbound
            remote-as 64512
            update-source tun0
        parameters {
            graceful-restart {
                stalepath-time 360
            router-id 192.168.255.5
    nhrp {
        tunnel tun0 {
            cisco-authentication ""
            holding-time 600
            map 192.168.255.2/28 {
                nbma-address 'your domain name'
                register
            multicast nhs
            shortcut
service {
    ssh {
        port 22
system {
    config-management {
        commit-revisions 100
    conntrack {
        modules {
            ftp
            h323
            nfs
            pptp
            sip
            sqlnet
            tftp
    console {
        device ttyS0 {
            speed 115200
    host-name VPS-R
    login {
        user vyos {
            authentication {
                encrypted-password 'your password'
    name-server 8.8.8.8
    name-server eth0
    ntp {
        server time1.vyos.net {
        server time2.vyos.net {
        server time3.vyos.net {
    syslog {
        global {
            facility all {
                level info
            facility protocols {
                level debug
vpn {
    ipsec {
        esp-group ESP-HUB {
            compression disable
            lifetime 3600
            mode transport
            pfs disable
            proposal 1 {
                encryption 3des
                hash md5
        ike-group IKE-HUB {
            close-action none
            ikev2-reauth no
            key-exchange ikev1
            lifetime 86400
            proposal 1 {
                dh-group 14
                encryption 3des
                hash md5
        ipsec-interfaces {
            interface eth0
        profile NHRPVPN {
            authentication {
                mode pre-shared-secret
                pre-shared-secret 'your password'
            bind {
                tunnel tun0
            esp-group ESP-HUB
            ike-group IKE-HUB
explain:
Certain local client and remote clients will send dns requests to the guestshell.The dns service will determine whether the domain name in the request is in the nation.If the domain name in the dns request is not in the nation, it will be sent to a secure DNS server through an encrypted tunnel, and route to correct nexthop.
   "listen": "0.0.0.0:53",
   "udp-max-bytes": 4096,
   "timeout": 5,
   "cache_expire_sec": 600,
   "domain2ip":{},
   "dns-china": [
      "192.168.0.254"
   "dns-abroad": [
	  "8.8.8.8"
   "chn_ip": [
      "chnroute.txt"
   "chn_domain": ["chnlist.txt"],
   "gfw_domain": ["gfwlist.txt"],
   "log_level": "error"
thanks a lot for this work
