887VA VDSL2 configuration problem
Kucko
I have 887VA router and trying to configure VDSL internet connection.
VDSL is working, but no IP address is set.
In interface Ethernet0 I was trying to use
ip address negotiated
and also
ip address dhcp
but no one gives me IP.
Internet is working on another non-Cisco router
Problem solved.
Only problem was the VLAN ID for VDSL LAN (not 101, but 2510). I found it on T-com pages: https://www.telekom.sk/wiki/internet/zakladne-nastavenia-siete
Correct config is attached.
Thanks for your help
18 Replies 18
balaji.bandi
make default interface eth0
try below config and let us know.
interface Ethernet0
no ip address
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
no shutdown
interface Dialer1
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication pap chap ms-chap callin
ppp chap hostname pisarsuk66@dslbasic
ppp chap password 7 15020D04503A2F
ppp ipcp address accept
no cdp enable
BB
try the configuration below (important parts marked in bold):
! Last configuration change at 21:36:32 CET Wed Jul 1 2020 by cisco
version 15.5
no service pad
service password-encryption
hostname ciscoR
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx.
enable password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa session-id common
ethernet lmi ce
memory-size iomem 10
clock timezone CET 1 0
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp pool LAN-POOL
network 192.168.1.0 255.255.255.0
default-router 192.168.1.220
dns-server 8.8.8.8 8.8.4.4
ip domain name my.home
ip name-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FCZ2019935X
license boot module c800 level advsecurity
vtp mode transparent
username cisco secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
controller VDSL 0
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
cdp enable
interface Ethernet0
no ip address
--> interface Ethernet0.101
--> encapsulation dot1Q 101
--> pppoe enable group global
--> pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description LAN
ip address 192.168.1.220 255.255.255.0
ip nat inside
--> interface Dialer0
mtu 1492
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ip forward-protocol nd
ip http server
ip http secure-server
--> ip nat inside source list NAT interface Dialer0 overload
--> ip route 0.0.0.0 0.0.0.0 Dialer0
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
--> access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community public RO
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
password 7 13361B130807132B3921796166
no modem enable
line aux 0
line vty 0 1
password 7 107D0518061C050A1E017B7977
transport input ssh
line vty 2 4
transport input none
scheduler allocate 20000 1000
ntp server 192.168.1.2
end
I was trying both solutions, but no success - no IP was assigned. Yesterday I was finishing at 3:00AM, so I could miss something.
I will review configuration at Monday and give you feedback.
Thanks for your help.
Who is your ISP ? What country are you in ?
Post the configuration again with the changes implemented, so we can double check...
Country is Slovakia, provider T-Com.
Changes was applied.
make the changes/additions marked in bold:
version 15.5
no service pad
hostname ciscoR
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
aaa new-model
ethernet lmi ce
ip domain name jupi.home
ip cef
no ipv6 cef
username jpi secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
controller VDSL 0
vlan 100
vlan 998
name native
interface ATM0
no ip address
shutdown
cdp enable
interface Ethernet0
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
description LAN
ip nat inside
ip tcp adjust-mss 1412
interface Dialer0
description Dialer for VDSL
mtu 1492
--> ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ppp chap password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
no cdp enable
ip http server
--> ip nat inside source list 1 interface Dialer0 overload
ip ssh time-out 60
ip ssh version 2
line con 0
no modem enable
line aux 0
line vty 0 1
transport input ssh
line vty 2 4
end
Still no IP
make the changes below:
--> no vlan 100
--> no vlan 998
name native
interface ATM0
no ip address
shutdown
cdp enable
interface Ethernet0
no ip address
--> no pppoe enable group global
I was trying also with
Still no IP assigned
Afterapplying
This line also dismissed:
Hello
Try the Following:
no interface Ethernet0.101
interface ATM0
no shut
interface ATM0.101 point-to-point
no ip address
pvc x/xx < ----isp provides this?
int dialer 0
shut
no shut
Kind Regards
Paul
Paul, I don't think, it's correct configuration.
Please, correct me, if I'm wrong.
1. As I understand, ATM0 interface is only for ADSL connection. I'm using VDSL2 Annex-A.
Here is info about my connection from my old Asus router:
DSL ModulationITU G.993.2(VDSL2)
Regional ModeA
DSL Exchange(DSLAM)Infineon(Lantiq)
Current Profile17a
2. As I can see from my previous logs, VDSL2 link is correctly connected, but only IP address was not negotiated. Today I was checked that protocol is CHAP, I was set it manually.
Problem solved.
Odd...they have been using Vlan 101 for ages...
Glad that you got it resolved, I don't think anybody would have figured that one out...Vlan 2510.
