about clear ip nat translation outside
rubberheart
Hi team ,
need your help with the " clear ip nat translation outside <local ip> <global ip >
I tried few times , but always get the " %translations not found",, but actually the translations are still there
the reason I dont want to do the clear ip nat translation * , is to avoid the affect other users.
please help !
Daniel
what if you use the 'forced' keyword, does that make a difference ?
clear ip nat translation outside <local ip> <global ip> forced
na,, tried that already, no luck. :(
