abr with pix
cfajardo1_2
i have a situation that goes like this;
network-----pix515------abr---ospf AS
previous setup is without pix. now iam inserting the pix and not planning to implement ospf. the outside ip addresses are of the old network and all traffic that goes out will be nated to that old range, thereby same as the old range the abr knows about.
the problem is i dont have access to the ABR thats why am justdoing my best to adapt.
do i need to do something on the abr in this case for the traffic to pass thru?
thanks alot.
smahbub
Level 6
Level 6
Yes you are correct. You have to configure the ABR to accept traffic from the PIX. For this you need to get access to the ABR. Can you get somebody to configure the ABR for this setup?
