Absurdly high packet rate shown on 887 router DSL interface
Mark Healey
I've run across a strange issue with Cisco 887 routers running IOS 15.1 using DSL
We use Solarwinds to monitor our network, and I noticed it was showing absurd data transfer rates in the Petabytes for one of our routers, I'd also experienced this at a previous employer but thought it was a glitch.
The router is an 887 running 15.1(4r)M, everything is working fine, but the packet rates are reporting incorrectly on the DSL connection.
Input on the ATM interface, and output on the Dialer and Virtual-Access interfaces, reports Petabytes of non-existent traffic.
Anyone have any idea what could be causing it?
VPN.Rtr.****#sh int atm0
ATM0 is up, line protocol is up
  Hardware is MPC/AOE ATMSAR, address is bc16.6513.5160 (bia bc16.6513.5160)
  MTU 1600 bytes, sub MTU 1600, BW 1252 Kbit/sec, RxBW 21488 Kbit/sec, DLY 370 usec,
     reliability 255/255, txload 12/255, rxload 255/255
  Encapsulation ATM, loopback not set
  Keepalive not supported
  Encapsulation(s): AAL5
  4 maximum active VCs, 1024 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input never, output 00:00:00, output hang never
  Last clearing of "show interface" counters 6d06h
  Queueing strategy: Per VC Queueing
  5 minute input rate 256667384420324000 bits/sec, 4172287691 packets/sec
  5 minute output rate 63000 bits/sec, 25 packets/sec
     719379813693604 packets input, 15548298477451310424 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     4570432 packets output, 1346394908 bytes, 0 underruns
     0 unknown protocol drops
VPN.Rtr.****#sh int dialer 1
Dialer1 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Description: Link To Broadband
  Internet address is ***.***.***.***/32
  MTU 1500 bytes, BW 1252 Kbit/sec, RxBW 21488 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 255/255, rxload 1/255
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi2
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 2w5d
  Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: weighted fair
  Output queue: 0/4096/64/0 (size/max total/threshold/drops)
     Conversations  0/0/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 939 kilobits/sec
  5 minute input rate 51000 bits/sec, 26 packets/sec
  5 minute output rate 255013886538779000 bits/sec, 172630289017136 packets/sec
     7670403 packets input, 3905355871 bytes
     7708060072495636923 packets output, 11355712667898331686 bytes
Bound to:
Virtual-Access2 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1500 bytes, BW 1024 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 255/255, rxload 12/255
  Encapsulation PPP, LCP Open
  Open: IPCP
  PPPoATM vaccess, cloned from Dialer1
  Vaccess status 0x44
  Bound to ATM0 VCD: 1, VPI: 0, VCI: 38, loopback not set
  DTR is pulsed for 5 seconds on reset
  Interface is bound to Di1 (Encapsulation PPP)
  Last input 00:00:00, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 881019518621180000 bits/sec, 1197403197849240 packets/sec
     7892510 packets input, 3918598067 bytes, 0 no buffer
     4507594221841637891 packets output, 9166828043806603740 bytes, 0 underruns
     0 carrier transitions
Leo Laohoo
This is definitely an IOS bug.
That's what I thought, but I've not been able to find an existing Bug ID for this one, and didn't want to submit it and find it was just a config hiccup
Well, the IOS you're running ends with an "M" and no number.  So this is the first "M" train (aka "M0").  So it's a bug.
No one has reported it to TAC so there's no bug ID available.
