Issue with NAT I think
brophy.n
Hi Everyone,
Trying to pick up some networking from the past and I'm running into an issue.
I have a router that can successfully ping the outside world and behind the router I have a PC that can ping the internal and external interfaces of the router but not the next hop or the outside world.
I'm guessing its an issue with NAT but if someone could point me in the right direction I would appreciate it.
Inside host: 192.168.1.50
Router:
Inside Interface 192.168.1.10
Outside Interface 192.168.137.10
Next Hop: 192.168.137.1
Config below if it helps.
*Mar  1 00:36:38.735: %SYS-5-CONFIG_I: Configured from console by console
R1#show run
Building configuration...
Current configuration : 1262 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
archive
 log config
  hidekeys
ip tcp synwait-time 5
interface Ethernet0
 ip address 192.168.137.10 255.255.255.0
 ip nat outside
 ip virtual-reassembly
 half-duplex
interface FastEthernet0
 ip address 192.168.1.10 255.255.255.0
 ip nat inside
 speed auto
interface Serial0
 no ip address
 shutdown
ip forward-protocol nd
ip forward-protocol spanning-tree
ip route 0.0.0.0 0.0.0.0 192.168.137.1
no ip http server
no ip http secure-server
ip nat pool RTR 192.168.137.10 192.168.137.10 netmask 255.255.255.252
ip nat inside source list 1 pool RTR overload
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 7 permit any
no cdp log mismatch duplex
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
R1#
11 Replies 11
Rejohn Cuares
Level 4
Level 4
1. Run a continuous ping from 192.168.1.50 to 4.2.2.2.
2. Issue this command "sh ip nat translation" and post the output here.
NAT examples for bed time reading:
http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/13772-12.html
Please rate replies and mark question as "answered" if applicable.
Pro Inside global      Inside local       Outside local      Outside global
icmp 192.168.137.10:23277 192.168.1.50:23277 4.2.2.2:23277   4.2.2.2:23277
icmp 192.168.137.10:23789 192.168.1.50:23789 4.2.2.2:23789   4.2.2.2:23789
icmp 192.168.137.10:24301 192.168.1.50:24301 4.2.2.2:24301   4.2.2.2:24301
icmp 192.168.137.10:24813 192.168.1.50:24813 4.2.2.2:24813   4.2.2.2:24813
icmp 192.168.137.10:25325 192.168.1.50:25325 4.2.2.2:25325   4.2.2.2:25325
icmp 192.168.137.10:25837 192.168.1.50:25837 4.2.2.2:25837   4.2.2.2:25837
icmp 192.168.137.10:26349 192.168.1.50:26349 4.2.2.2:26349   4.2.2.2:26349
icmp 192.168.137.10:26861 192.168.1.50:26861 4.2.2.2:26861   4.2.2.2:26861
icmp 192.168.137.10:27373 192.168.1.50:27373 4.2.2.2:27373   4.2.2.2:27373
icmp 192.168.137.10:27885 192.168.1.50:27885 4.2.2.2:27885   4.2.2.2:27885
icmp 192.168.137.10:28397 192.168.1.50:28397 4.2.2.2:28397   4.2.2.2:28397
icmp 192.168.137.10:28909 192.168.1.50:28909 4.2.2.2:28909   4.2.2.2:28909
icmp 192.168.137.10:29421 192.168.1.50:29421 4.2.2.2:29421   4.2.2.2:29421
icmp 192.168.137.10:29933 192.168.1.50:29933 4.2.2.2:29933   4.2.2.2:29933
icmp 192.168.137.10:30445 192.168.1.50:30445 4.2.2.2:30445   4.2.2.2:30445
icmp 192.168.137.10:30957 192.168.1.50:30957 4.2.2.2:30957   4.2.2.2:30957
icmp 192.168.137.10:31469 192.168.1.50:31469 4.2.2.2:31469   4.2.2.2:31469
icmp 192.168.137.10:31981 192.168.1.50:31981 4.2.2.2:31981   4.2.2.2:31981
icmp 192.168.137.10:32493 192.168.1.50:32493 4.2.2.2:32493   4.2.2.2:32493
Your NAT config looks fine. What is the result if you run this command on the router - "ping 4.2.2.2 source FastEthernet0"
Do you have access to 192.168.137.1? Could you please tell me why you hardcoded half-duplex on interface Ethernet0?
I'm starting to suspect it might be an issue with access lists
I also tested static NAT and that works just fine
R1(config)#do ping 4.2.2.2 source FastEthernet0
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Packet sent with a source address of 192.168.1.10
Success rate is 60 percent (3/5), round-trip min/avg/max = 52/58/72 ms
Success rate is 80 percent (4/5), round-trip min/avg/max = 48/53/56 ms
Success rate is 80 percent (4/5), round-trip min/avg/max = 48/76/124 ms
R1(config)#
Based on your ICMP tests, you experienced packet drops this is due to collisions (half duplex on your end and on the other end could be set to full duplex). Kindly check the interface stats to confirm this - "show int Ethernet0"
This is just test environment so I'm fine with dropped packets.
I just want to get NAT working.
Did you read the document I posted?
Here it is again. Go to section "Configuring NAT to Allow Internal Users to Access the Internet Using Overloading"
yes i read through it and I thought I have everything correct.
I'll give it another go though
I have verified you config in GNS3 and it is all good, no issues found.
Topology:
R1  <<>> R2 <<>> R3
R1:
interface Loopback1
 ip nat inside
 ip virtual-reassembly in
interface FastEthernet0/0
 ip nat outside
 duplex auto
 speed auto
R2:
 ip address 192.168.137.1 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.10.1 255.255.255.0
 duplex auto
 speed auto
ip route 0.0.0.0 0.0.0.0 192.168.10.2
R3:
interface Loopback1
 ip address 4.2.2.2 255.255.255.255
 ip address 192.168.10.2 255.255.255.0
 duplex auto
 speed auto
ip route 192.168.137.0 255.255.255.0 192.168.10.1
Verification:
R1#ping 4.2.2.2 source loo1
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/38/64 ms
R1#
R1#sh ip nat trans
icmp 192.168.137.10:8  192.168.1.1:8      4.2.2.2:8          4.2.2.2:8
Everything looks good as far as I can tell.
Not sure where I'm going wrong
Will half-duplex have anything to do with it?
