accees from wan to a router
yokaso007
i am looking to access from my home to my work with internet.
i have a static ip in my modem router, and i want to gain access to my modem router from my home.
can you give an idea?
thank you
mfurnival
Level 4
Level 4
Do you mean you want to connect to your home router when you are at work?
Or do you mean you want to connect to your workplace from your home using your home router?
the second, yes i want to connect from my home to my workplace.
Pasting  a VPN configuration could be a little bit difficult. Because, I don't  know which IOS, VPN Client, Client Platform, etc. you use.
Once I worte a VPN Setup for Apple iPhone and iPad usage, maybe this will help you a little.
https://supportforums.cisco.com/message/3835229#3835229
Kind regards
Kai
What you are asking is certainly possible but we would need a lot more information about your home router, your workplace setup etc. It should also be said that if your company will probably have a policy regarding remote access and they won't just let any old person connect any old bit of kit to their network.
