04-19-2016 01:36 AM - edited 03-05-2019 03:49 AM
I've got a ASR 1002-X that's currently licensed as IPBase. It's currently booting "bootflash:/asr1002x-universalk9.03.13.05.S.154-3.S5-ext.SPA.bin".
I'd like to do DMVPN with IPSec encryption. How do I go about doing this?
I've accepted the EULA, and have temporarily activated 'advipservices', but the log shows me that %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF and 'show license' shows me
Index 19 Feature: ipsec
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Count: Non-Counted
License Priority: None
How do I accept this EULA?
I just want to get things tested before purchasing the applicable license..
Many Thanks!
04-19-2016 06:34 AM
I finally found out what was causing this issue.
I had declared an ipsec profile, but hadn't applied it to any interfaces. Applying it to a tunnel interface caused everything to kick into life.
03-25-2017 03:10 AM
Hi Spencer!
How did you get off from this one?
