Access-List Deny IP Range
tim.smith
I need to temporarily block two IP subnets at a remote site from reaching across the WAN, but they need to talk to each other in the meantime.  These subnets exist on my 4451 at Gi0/0/1.70 (10.63.70.0/24) and Gi0/0/1.71 (10.63.71.0/24), and they need to be blocked from reaching out across Gi0/0/0 (WAN interface).
Could someone show me a simple ACL to apply and where to apply it?
Thanks.
the below should be sufficient:
access-list 101 deny ip 10.63.70.0 0.0.0.255 any
access-list 101 deny ip 10.63.71.0 0.0.0.255 any
access-list 101 permit ip any any
interface GigabitEthernet0/0/0
ip access-group 101 in
That look great and mostly accurate from what little I know about ACLs.
I just have a question about how it is applied to that interface... Should it be applied to the inbound as you have it or the outbound of the WAN interface?
What if I wanted to block anything (IP or any other traffic) on those 2 sub-interfaces from reaching across the WAN (Gi0/0/0)?
applying the access list inbound is recommended (traffic does not actually traverse the interface before it  processed).
Also, if you use NAT on your interfaces, you can also simply exclude the subinterfaces from the NAT process (no ip nat inside)...
Giuseppe Larosa
Hello Tim,
I would use two extended ACLs applied inbound on both subinterfaces
access-list 170 permit ip 10.63.70.0 0.0.0.255 10.63.71.0 0.0.0.255
access-list 170 deny ip any any
access-list 171 permit ip 10.63.71.0 0.0.0.255 10.63.70.0 0.0.0.255
access-list 171 deny ip any any
interface gi0/0/1.70
ip access-group 170 in
exit
interface gi0/0/1.71
ip access-group 171 in
exit
This provides the most granular control on what the two subnets can do.
Hope to help
Giuseppe
