Access-list From WEB
estelamathew
Level 2
Level 2
Hello Friends,
i have a WEB Server and Exchange (OWA) servers in my internal network, I have a internet router 2821 with leased line and ADSL, i want to classify traffic in route map for these servers to pass through leased line and other users through ADSL how can i do that.
For ex :WEB Server ip add   10.10.10.10
            Exchange IP add     10.10.10.11
               Users IP Add :      10.10.0.0
Can anybody help me to write access-list for webservers and exchange (SMTP) servers so that they can initiate traffic and recieve from internet.
WEBSERVER: HTTP/HTTPS
OWA: HTTP/SMTP
3 Accepted Solutions
joyride_us2
you need policy-based routing with a 'set ip next-hop' statement in your route-map.
access-list WEBMAIL extended ip permit 1.host 10.10.10.10 any
access-list WEBMAIL extended ip permit 1.host 10.10.10.11 any
route-map WEBMAIL
match ip access-group WEBMAIL
set ip next-hop (or whatever is in your IOS for the same purpose!) IP_ADDRESS_LEASED_LINE
and finally ip route 0.0.0.0 0.0.0.0 IP_ADDRESS_ADSL_CONNECTION
on your inside interface (Fa0/0 for example) :
int Fa0/0
ip addres....
service-policy WEBMAIL in
The route-map will be evaluated before the routing table.
Hope this helps!
By the way, I just checked the command : it is not a 'service-policy...' you want under your inside interface but an :
'ip poicy route-map WEBMAIL''
Cheers
1. the ACL on the outside interface is a security matter not a routing matter : be my guest!
2. no, the 'permit any' in the route-map is not necessary. The denied traffic will not be routed by any route-map statement and should be routed by regular routing table then. No dropped traffic.
5 Replies 5
joyride_us2
route-map WEBMAIL
int Fa0/0
ip addres....
Hope this helps!
Cheers
Hello Dear,
I hope there should be access-list for outside interface of internet router.???? for  inbound traffic for HTTPS and HTTPand smtp .I want specific access-list on inside interface also  i don't want to permit all protocol by specifying IP on  internet router can u help me with inside and outside specific access-list.
I hope u missed route-map permit 20 for the users subnet otherwise they will be blocked??? correct me if i m wrong.
route-map WEBMAIL permit 10
match access-list ?????
set  ip Next hop  < ISP ADDRESS>
route-map WEBMAIL permit 20
match access-list 10
set interface dialer 0
access-list 10 permit 10.10.0.0 0.0.255.255
Thnaks
thanks !!!!
