10-20-2008 07:14 AM - edited 03-04-2019 03:13 AM
Pls see the attah.
Moses
Also post on Network management
10-20-2008 07:33 AM
Post configs of both routers.That will clarify routing info and the VPN networks.
From the config lines from the attachment .
There is " deny " statement in the access list bound to interfaces on both routers for network 192.0.0.0/8 .Check if this is not blocking the ping.
Saju
Pls rate helpful posts
10-20-2008 08:26 AM
10-20-2008 08:39 AM
yes include 192.0.0.0/8 subnet to the Crypto ACL if you want to encrypt the traffic.
10-20-2008 09:04 AM
Yes lets say i do not want to encrypt the 192.0.0.0/8 traffic. Lets say that i want to deny that traffic. Why is not working with the access list? Does match address of the crypto map interferes with the access list on the interface.
Moses
10-20-2008 10:23 AM
Hi Moses,
Since you did not specify 192. network in the Crypto ACL so it will will never go into tunnel(or it will not be encrypted)
I think your ping to 192 network is blocked by the outbound access-list on Router A
try removing it and then test
interface Serial1/3.6 point-to-point
description RouterA
no ip access-group AList out
Extended IP access list AList
10 deny ip 192.0.0.0 0.255.255.255 any =========> this is blocking your ping packets(30 matches)
11 deny ip host 10.9.9.12 any
20 permit ip any any (4576 matches)
Saju
