Access-lists Not working on Router
Jonathan Nali
Hi Everyone,
I need your help with this configuration.
The same configuration one my other with on a different branch but these configs are not working on my other branch.
I can reach the interface 10.10.1.1 and go to the internet without access-lists, yet I needed ACLs on my other router to do the same.
Now, what's the problem with that? I cannot reach the 10.10.1.0/24 LAN because this line:
->access-list 113 deny ip 10.10.3.0 0.0.0.255 10.10.1.0 0.0.0.255
if I am not mistaken should read, deny any ip address from the .3.0/24 network from being NATted
The path from this router should be:
GW:192.168.124.9
GW:192.168.124.1
GW:192.168.124.2
Router Interface:10.10.1.1
Problem 2: I can ping all those but when I do a traceroute to 10.10.1.1 or 192.168.124.2 the trace dies on 192.168.124.1, which is super confusing.
ip source-route
ip dhcp relay information option
ip dhcp relay information trust-all
ip dhcp excluded-address 10.10.3.253
ip dhcp excluded-address 10.10.3.252
ip dhcp excluded-address 10.10.3.1 10.10.3.50
ip dhcp pool KITWE-POOL
network 10.10.3.0 255.255.255.0
default-router 10.10.3.3
dns-server 10.10.1.4
ip cef
no ip domain lookup
ip name-server 8.8.8.8
no ipv6 cef
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface FastEthernet0
switchport access vlan 10
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet8
ip dhcp relay information option-insert
ip address 192.168.124.10 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 10.10.3.3 255.255.255.0
ip helper-address 10.10.3.3
ip directed-broadcast
ip nat inside
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip forward-protocol udp talk
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 113 interface FastEthernet8 overload
ip route 0.0.0.0 0.0.0.0 192.168.124.1
ip route 10.10.2.0 255.255.255.0 192.168.124.9
ip route 192.168.124.0 255.255.255.252 192.168.124.9
ip route 192.168.124.8 255.255.255.252 192.168.124.9
access-list 113 deny ip 10.10.3.0 0.0.0.255 10.10.2.0 0.0.0.255
access-list 113 permit ip 10.10.3.0 0.0.0.255 any
no cdp run
Any Advice will be highly appreciated.
2 Accepted Solutions
Giuseppe Larosa
Hello @Jonathan Nali ,
in your configuration you are doing something different
where 192.168.124.9 is the next-hop for Fas8
ip nat outside
If you want to reach subnet 10.10.1.0/24 from 10.10.3.0/24 without being NATTed you should add a line for that in your ACL used for NAT
Hope to help
Giuseppe
RicardoSN
Not exactly Jonathan,
If you want the source network 10.10.3.0/24 not to be natted to the IP 192.168.124.10 when it's trying to reach the destination network 10.10.1.0/24, then what you should do is denying that source & destination on your NAT ACL, which i belive is the ACL 113:
Like this:
As you're currently denying an incorrect destination network i belive 10.10.2.0/24.
-Ricardo S.N., Regards!
Giuseppe Larosa
ip nat outside
Hope to help
Giuseppe
Hi @paul driver @RicardoSN @Giuseppe Larosa ,
Thank you for your responses.
We discovered that the problem was with the ISP. They had no advertised the routers to my LAN.
RicardoSN
Like this:
Hello
Just like to add, would suggest to remove route source routing, you do not want source addressing specify the route path also regards your static routing specify the physical interface of the next-hop also so recursive routing isnt invoked by the other static routes for the next-hop
no ip source-route
no ip route 0.0.0.0 0.0.0.0 192.168.124.1
no ip route 10.10.2.0 255.255.255.0 192.168.124.9
no ip route 192.168.124.0 255.255.255.252 192.168.124.9
no ip route 192.168.124.8 255.255.255.252 192.168.124.9
ip route 0.0.0.0 0.0.0.0 <interface> 192.168.124.1
ip route 10.10.2.0 255.255.255.0 <interface> 192.168.124.9
ip route 192.168.124.0 255.255.255.252 <interface> 192.168.124.9
ip route 192.168.124.8 255.255.255.252 <interface> 192.168.124.9
Kind Regards
Paul
