Access netwerk on network through site-to-site vpn with anyconnect
Dear users,
Situation:
On the left i've got an asa (asaL) and on the right i got another one (asaR).
These asa's are connected to eachother using site-to-site vpn.
I can access a network on asaR when I am behind the firewall of asaL.
However when I am connected using anyconnected vpn client to asaR and trying connected to a network on asaL it fails.
So the tunnel seems to be oke, but when anyconnect comes in the pictures it fails..
Looking forward to your suggestions.
Thanks in advance.
Kind regards,
Fabian
Richard Burts
Fabian
There are several things that could produce the symptoms that you describe and you have not given us enough information to know which of them it might be. Let me describe some of them and hope that you can figure it out or else you will need to provide details of how one or both ASA are configured.
1) It might be in the configuration of the site to site tunnel. There is an access list which determines what traffic goes through the VPN and if the address pool of AnyConnect is not included in that access list then AnyConnect would not be able to go through the VPN tunnel.
2) It might be in the configuration of AnyConnect, especially if you configure it to use split tunneling. If it does use split tunneling then you identify what network resources AnyConnect will send through its encrypted tunnel. If the network of asaR are not included in the list of AnyConnect on asaL then AnyConnect will not go through the site to site tunnel.
3) If it does not seem to be either of the issues above then it might be that the packet arrived on the public interface of the ASA and needs to be forwarded back out the same interface to use the site to site VPN. That is not allowed by default and you may need to enable same security level traffic intra interface.
Rick
Rick
Dear Rick,
  1. This network is added so this one is correct.
  2. This one is also set correct.
  3. This one is also correct..
Maybe this error from the logging will help you:
5 May 24 2016 06:41:05 305013 172.24.0.2 61289 8.8.4.4 53 Asymmetric NAT rules matched for forward and reverse flows; Connection for udp src outside:172.24.0.2/61289(LOCAL\optimezers) dst outside:8.8.4.4/53 denied due to NAT reverse path failure
Looking forward to hear for you.
Kind regards,
Fabian
Fabian
Thank you for clarifying that none of the possible issues that I suggested are involved in your issue. The log message is quite helpful. It clarifies that the issue is an inconsistency in NAT. What frequently happens is that a network is included in the access list for the site to site VPN but that network traffic going over the VPN is not exempted from address translation. Since we do not know the details of your situation we can not know if this is the issue but it is where I suggest that you start looking.
Rick
Rick
