IOS XR | RPL for BGP multihoming routing manipulation
Ibrahim Jamil
Level 6
Level 6
Hello Cisco experts
 kindly , any Configuration example with RPL for BGP multihoming routing manipulation
thanks all
7 Replies 7
Vinit Jain
Can you please elaborate your question. What kind of route manipulation you are looking for. there is a very brief example of RPL that we used in IOS XR workbook that we created sometime back:
https://supportforums.cisco.com/document/12068666/introduction-cisco-ios-xr-technical-workbook
If there is anything specific that you are looking for, then please do let me know.
Vinit
--Vinit
Hi vinit
thanks for answering
I have this book along with XR book from ciscopress , didn't help
bro i need the same Syntax in the below link but for IOS XR  , i have the same scenario
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13762-40.html#conf5
thanks
Hello Ibrahim
I will look into this configuration and get back to you with the solution.
Vinit
--Vinit
Hello bro vinit
thanks thanks a lot , i am waiting this one bro
thanks
Hello vinit
did y make it bro
thanks
Hello Ibrahim
Please find the configuration for router R2:
router bgp 100
address-family ipv4 unicast
network 10.10.10.0/24
network 10.10.20.0/24
exit
neighbor 192.168.21.1
remote-as 100
next-hop-self
neighbor 192.168.42.4
remote-as 400
route-policy AS400-In in
route-policy AS400-Out out
if as-path in (ios-regex '^400$') then
set local-preference 150
pass
endif
end-policy
if destination in (10.10.10.0/24) then
prepend as-path 100
pass
elseif destination in (10.10.20.0/24) then
pass
else
drop
endif
end-policy
Hope this helps.
You can build the other configuration based on this.
Vinit
--Vinit
thanks vinit
bro can u drop me ur e-mail ID in  private msg , so that i communicate with you
, i have seen ur profile at ciscolive , you are the king of BGP , bro i have complex BGP Multihoming , i cant publish details PI IPs and AS here
i need ur help to complete this
thanks bro
