Accessing local server using public IP within the network
hirani89
I want to access a server using the public IP from the same internal network.
Please the config below
ip dhcp excluded-address 192.168.0.1 192.168.0.100
ip dhcp excluded-address 192.168.3.1
ip dhcp pool HOME
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.1
 dns-server 1.1.1.1 1.0.0.1
ip dhcp pool WIN
 host 192.168.0.22 255.255.255.0
 client-identifier 01d4.3d7e.18d9.ce
ip dhcp pool WIN2
 host 192.168.0.247 255.255.255.0
 client-identifier 0152.5400.45da.74
ip dhcp pool Solar
 host 192.168.0.253 255.255.255.0
 client-identifier 01c8.9346.3250.e8
ip dhcp pool Tank-Level
 host 192.168.0.243 255.255.255.0
 client-identifier 018c.aab5.8b8e.40
ip dhcp pool OctoPrint
 host 192.168.0.229 255.255.255.0
 client-identifier 01dc.a632.2ce3.8c
ip domain name mydomain.com
no ipv6 cef
license udi pid CISCO2921/K9 sn FGL1813118M
username admin privilege 15 secret 4 HJuTQycLGFn/1VtTta/OeXqUIqQROubxT/D40OGFs0c
redundancy
ip ssh version 2
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.100
 description -Ethernet WAN-
 encapsulation dot1Q 100
 ip address pub.lic.add.ress 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
interface GigabitEthernet0/1
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/2
 ip address 192.168.3.1 255.255.255.0
 duplex auto
 speed auto
ip default-gateway gate.way.add.ress
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list NAT interface GigabitEthernet0/0.100 overload
ip nat inside source static udp 192.168.0.30 80 interface GigabitEthernet0/0.100 80
ip nat inside source static tcp 192.168.0.30 80 interface GigabitEthernet0/0.100 80
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0.100 gate.way.add.ress
ip route 192.168.2.0 255.255.255.0 192.168.3.2
ip access-list standard IoT
 permit 192.168.2.0 0.0.0.255
ip access-list extended NAT
 permit ip 192.168.0.0 0.0.0.255 any
control-plane
line con 0
 logging synchronous
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 5 0
 login local
 transport input ssh
scheduler allocate 20000 1000
I want access 192.168.0.30 using pub.lic.add.ress from with in the network. I have tested the port forwarding. I am able to access the server from another network.
balaji.bandi
why not have local DNS Entry to access internally? (rather complicate engineering) ?
if the above case not workable what is the challenge here?
BB
what you need is NAT hairpinning. Make the changes/additions marked in bold:
ip dhcp pool HOME
ip dhcp pool WIN
ip dhcp pool WIN2
ip dhcp pool Solar
no ipv6 cef
redundancy
ip ssh version 2
no ip address
shutdown
--> interface Loopback0
--> ip address 169.254.1.1 255.255.255.255
--> ip nat inside
no ip address
duplex auto
speed auto
ip nat outside
--> ip nat outside
--> ip policy route-map PBR_NAT_RM
duplex auto
speed auto
--> ip nat outside
duplex auto
speed auto
no ip http server
ip dns server
--> ip nat inside source list NAT_ACL interface GigabitEthernet0/0.100 overload
--> ip nat inside source list NAT_HAIRPIN_ACL interface Loopback0 overload
--> ip access-list extended NAT_ACL
--> deny ip 192.168.0.1 0.0.0.255 192.168.0.1 0.0.0.255
--> deny ip 192.168.3.0 0.0.0.255 192.168.3.0 0.0.0.255
--> permit ip 192.168.0.1 0.0.0.255 any
--> permit ip 192.168.3.0 0.0.0.255 any
--> ip access-list extended NAT_HAIRPIN_ACL
--> permit ip 192.168.0.1 0.0.0.255 host 192.168.0.30
--> permit ip 192.168.3.0 0.0.0.255 host 192.168.0.30
--> route-map PBR_NAT_RM permit 10
--> set interface Loopback0
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
exec-timeout 5 0
login local
transport input ssh
Hello
You have two options:
Domainless nat
int gig0/1
no ip nat inside
ip nat enable
no ip redirects
int gig0/0.100
no ip nat outside
no ip redirects
ip nat enable
no ip nat inside source list NAT interface GigabitEthernet0/0.100 overload
no ip nat inside source static udp 192.168.0.30 80 interface GigabitEthernet0/0.100 80
no ip nat inside source static tcp 192.168.0.30 80 interface GigabitEthernet0/0.100 80
ip nat source list NAT interface GigabitEthernet0/0.100 overload
ip nat source static udp 192.168.0.30 80 interface GigabitEthernet0/0.100 80
ip nat source static tcp 192.168.0.30 80 interface GigabitEthernet0/0.100 80
Hairping Nat
int loopback 100
description hairpin
ip address 169.254.255.254 255.255.255.255
ip nat inside
route-map NAT_PBR
set interface loopback 100
int gig0/0.100
ip nat outside
5 deny ip 192.168.0.0 0.0.0.255 192.168.0.0 0.0.0.255
ip access-list NatPin
permit ip 192.168.0.0 0.0.0.255 host 192.168.1.30
int gig0/1
ip nat outside
no ip redirects
ip policy-route NAT_PBR
ip nat inside source list NatPin interface loopback100
Kind Regards
Paul
