ACE Connectivity
Mikey John
Hi All,
I've 2 units of Cisco 4948 switches connected via trunk.
1st-4948 is the ACTIVE switch
2nd-4948 is the STANDBY switch
& I have 1 ACE 4710 .
If I connect all 4-ports in a port-channel to the 1st-4948 ACTIVE switch (shown below), when the failover happens ACE will lose the connectivity.
Please advise the best possible  connectivity options based on the above scenario.
I am looking for a valid justification why we cannot have two port-channels  Active/standby mode connecting to two different  Active\Standby switches.
Appreciate your reply.
Cheers
Mikey
Mikey John
Hi All,
Would appreciate if someone please replies to this post.
Thanks in advance.
Cheers
Mikey
Jon Marshall
Are you saying you know you can't use 2 port channels or not ?
I am confused as to what you mean. Simply connect the ACE device to both switches, using a portchannel on each switch. One will probably block due to STP but will become active if the other uplink fails.
If i have misunderstood please clarify.
Jon
