Acess-list issue on Cisco Router 3945
Hi All,
I reported a really strange issue on a Cisco Router 3945. Here below info about release software used:
IOS:C3900-UNIVERSALK9-M, Version 15.2(2)T, Release software (fc1)
ROM: System Bootstrap, Version 15.0(1r)M13, release software (fc1)
System image file: "flash0:c3900-universalk9-mz.SPA.152-2.T.bin"
Please look at a brief extract of router running configuration file:
ip access list extended 180
permit ip any any
interface fastethernet 0/0/1
ip access-group 180 in
It’s an easy configuration of Extended ACL and the application on an Ethernet interface. The expected result is:
- The interface works properly (because access list is permitting every kind of data traffic in input)
- Checking “show access-list 180”, the counter of matched packets increments for all the packets that are forwarded inside the fa0/0/1.
But actually the Fastethernet 0/0/1 drops all the packets as if all the packets don’t match with access list (And this behavior is really incredible). The interface couldn't be used anymore because any kind of data traffic is denied.
I hope I made myself clear with the explanation of that issue.
Thank you
You got a txload of 100%?
Router_2#show int fa0/0/1
FastEthernet0/0/1 is up, line protocol is up
Hardware is FastEthernet, address is c471.fe1b.a712 (bia c471.fe1b.a712)
Description: Voice
Internet address is 10.255.1.252/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 255/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
14 Replies 14
Richard Burts
Interface fastethernet0/0/1 does not look to me like one of the built in interfaces for the 3945. Can you tell us about this interface and what it is? Perhaps it would also help if you would post the output of show version and of show ip interface brief.
I am wondering if there are some restrictions on this interface, such as its being a layer 2 switching interface rather than a layer 3 interface?
Rick
Rick
Dear Richard,
The fastethernet interface is a HWIC-2FE mounted into Cisco router 3945. Here below the "show ip int fa0/0/1":
Router_1#show ip int fa0/0/1
Broadcast address is 255.255.255.255
Address determined by non-volatile memory
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Multicast reserved groups joined: 224.0.0.2 224.0.0.5
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is enabled
IP CEF switching turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is enabled, using route map Turksat
Network address translation is disabled
BGP Policy Mapping is disabled
Input features: Policy Routing, MCI Check
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
Here below "show version" and "show ip int brief":
Router_1#show version
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.2(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 16-Nov-11 00:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
Router_1 uptime is 1 week, 1 day, 23 hours, 53 minutes
System restarted at 08:16:01 UTC Sat Mar 10 2012
System image file is "flash0:c3900-universalk9-mz.SPA.152-2.T.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE150/K9 with 2029568K/67584K bytes of memory.
Processor board ID FCZ155220G9
6 FastEthernet interfaces
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
497448K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#    PID                                        SN
*0             C3900-SPE150/K9       FOC15463NPQ
Technology Package License Information for Module:'c3900'
Technology   Technology-package           Technology-package
                      Current       Type                 Next reboot
ipbase           ipbasek9     Permanent       ipbasek9
security         None           None                None
uc                 None           None                None
data              None           None                None
Router_1#show ip int brief
Interface                                       IP-Address     OK? Method       Status                          Protocol
Embedded-Service-Engine0/0      unassigned     YES NVRAM      administratively down   down
GigabitEthernet0/0                        unassigned     YES NVRAM      up                                up
GigabitEthernet0/0.400                172.16.0.2     YES NVRAM        up                                up
GigabitEthernet0/1                       100.1.7.252     YES NVRAM      up                                up
GigabitEthernet0/2                       100.1.3.252     YES NVRAM      up                                up
FastEthernet0/0/0                        100.1.8.252     YES NVRAM      up                                up
FastEthernet0/0/1                        10.255.1.252   YES NVRAM      up                                up
down
Thank you in advance for your support
Claudio
Your interface is administratively down? Is this right? Or was it just at the time when you made the output of the commands.
Claudio
Thank you for the additional information which I requested. It is helpful to know that the interface is part of HWIC-2FE. This confirms that it should operate as a normal layer 3 interface and should do normal processing of access lists. And that makes this issue more puzzling.
If you want to investigate this further I would suggest to re-configure the access list and apply it to the interface. After you have run some traffic and observe the problem is still happening then post the output of show run interface fast0/0/1, the output of show ip interface fast0/0/1, and of show access list.
An additional question would be whether you would experience the same problem on the interface fast0/0/0 and on any of the built in Gig interfaces? I am wondering if it might be something related to the HWIC-2FE?
Rick
Rick
Does this interface forward the traffic properly without this access-list applied?
Dear Vasileios,
the interface is working properly without the access-list applied.
Thank you
Claudio
Hi Claudio,
I have a few comments from your show ip interface outputs.
It is stated the next for the fa0/1/1 interface.
Did you have apply the access-list before this show command?
I also noticed a policy routing have been applied to the show ip interface
Could possibly cause a confilict with the routing via this interface?
Finally, could you try to also log the packets with the access-list and check these captured packets.
permit ip any any log
Do you have any errors to this interface?
Attention, if you use this router to a production network and the interface has high traffic utilization.
BR
Vasilis
Vasilis
This is a very good observation that Polic Based Routing is applied to the interface. We certainly need to know what is in the configuration of PBR.
Rick
Rick
Dear all,
I tried to apply the access-list also to other interfaces (on board as gi0/1 or in another HWIC-2FE as fa0/1/0) but the issue persist.
Then, I erased the PBR configuration and the problem persist again.
Here below I report "show ip int fa0/0/1", "show in fa0/0/1" and "show access-list 180" after applying the access-list in the fa0/0/1 interface:
Router_2#show ip int fa0/0/1
MTU is 1500 bytes
Multicast reserved groups joined: 224.0.0.2 224.0.0.5 224.0.0.6
Inbound access list is 180
Policy routing is disabled
Input features: Access List, MCI Check
Description: Voice
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 42000 bits/sec, 33 packets/sec
5 minute output rate 4000 bits/sec, 7 packets/sec
     591386 packets input, 47238160 bytes
     Received 97102 broadcasts (0 IP multicasts)
     0 watchdog
     0 watchdog
     501910 packets output, 40504970 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
Router_2# show access-lists 180
Extended IP access list 180
   10 permit ip any any
Description: Voice
Dear Marko,
I confirm that value. Even if I disable the access-list applied in that interface and there is no data traffic through it the txload is 255/255. I found that value not only in fa0/0/1 interface but in all the interfaces of that router.
Claudio
Hi Claudio,
I  aslo noticed that you have the next bitrates to this interface
I recommend you to check the process of the router and check the processes with high value
sh proc cpu sorted
sh proc cpu history
Provide the output.
Try to capture these packets with debug ip packet AL, access-list which log packets or even better with Wireshark.
It is needed to find out what are these packets and why are produced
BR
Vasilis
Dear all,
I solved that issue with a downgrade of the IOS. Now I'm using a:
c3900-universalk9-mz.SPA.151-3.T2
and all the access-list are working properly and also txload now is 1/255.
Probably the IOS C3900-UNIVERSALK9-M, Version 15.2(2)T has got a bug regarding that.
Thank you all for your support
Claudio
Claudio
Thanks for posting back to the forum indicating that you had solved the problem by using a different version of IOS. I had been thinking that the symptoms sounded like a possible IOS bug and had been looking for some reference that would support that. Thanks for confirming that this was indeed the issue. Now that the problem is solved perhaps you would mark the issue as answered so that other readers would know that there is a solution?
Rick
Rick
