Multiple VLANS - one switchport
petrutz_21
Hi,,
I have a CISCO 2801 router with one HWIC-4ESW module. I've created 4 vlans. How can i assign those 4 vlans to just one interface from the
HWIC-4ESW module? For example i want to use just interface FastEthernet0/3/0.
interface FastEthernet0/3/1
interface FastEthernet0/3/2
interface FastEthernet0/3/3
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.1.1 255.255.255.192
ip nat inside
interface Vlan20
ip address 192.168.1.65 255.255.255.192
ip nat inside
rate-limit output access-group 101 8000000 3000000 7000000 conform-action transmit exceed-action drop
rate-limit output access-group 102 8000000 3000000 7000000 conform-action transmit exceed-action drop
interface Vlan30
ip address 192.168.1.129 255.255.255.192
ip nat inside
interface Vlan40
ip address 192.168.1.193 255.255.255.192
ip nat inside
thanks,
CHARLES BRONSON
Toma,
Set your router config back to the configuration you first listed, then make FastEthernet0/3/0 a trunk port using the commands that Dan-Ciprian gave you. This will make that interface a trunk port which will carry traffic tagged for any allowed VLAN. By default, a trunk port will pass traffic for any VLAN configured on the device. Then connect the FastEthernet0/3/0 port to a port on your D-Link switch. A quick google search showed that your model switch supports 802.1Q (VLANs). You will need to look at D-Links' configuration manual for the next steps. On your D-Link, configure the port that connects to your Cisco 2801 to be a trunk port, then configure the other ports on the switch as Access ports and assign them to the individual VLAN you want the connected PC to use.
A trunk port carries traffic for all allowed VLANs. An access port carries traffic for only one VLAN and you need to configure the port for the one VLAN you want it to configure. I hope this makes sense.
19 Replies 19
Hi Toma,
4ESW is basically a switch integrated in the 2801 - that's why you are able to configure interface vlan (SVI).
You are able to configure as a trunks any interface of the HWIC.
switchport mode trunk
Dan
HI,
I have configured interface FastEthernet0/3/0 in trunk mode but the pc can get any ip from dhcp server.
Here is the conf :
ip dhcp pool IT_1
   network 192.168.1.0 255.255.255.192
   domain-name xxx.com
   default-router 192.168.1.1
   dns-server 193.226.128.1 193.226.128.129
   lease 20
ip dhcp pool HQ_1
   network 192.168.1.64 255.255.255.192
   domain-name xxx.com
   default-router 192.168.1.65
   lease 20
ip dhcp pool HQ_2
   network 192.168.1.128 255.255.255.192
   domain-name xxx.com
   default-router 192.168.1.129
   lease 20
ip dhcp pool IT_2
   network 192.168.1.192 255.255.255.192
   domain-name xxx.com
   default-router 192.168.1.193
   lease 20
interface Vlan1
no ip address
interface Vlan10
description IT_1
ip nat inside
interface Vlan20
description HQ_1
ip nat inside
interface Vlan30
description HQ_2
ip nat inside
interface Vlan40
description IT_2
ip nat inside
Richard Burts
Toma
If you want to assign multiple VLANs to a single switch port then you would configure that interface as a trunk. The configuration might look something like this
switchport trunk allowed vlan 10,20,30,40
Rick
Rick
When i try to insert :
the command is rejected:  "Bad VLAN allowed list. You have to include all default vlans, e.g. 1-2, 1002 -1005."
petrutz_21
VLAN Name                             Status    Ports
1    default                          active    Fa0/3/1, Fa0/3/2, Fa0/3/3
10   IT_1                             active
20   HQ_1                             active
30   HQ_2                             active
40   IT_2                             active
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        1002   1003
10   enet  100010     1500  -      -      -        -    -        0      0
20   enet  100020     1500  -      -      -        -    -        0      0
30   enet  100030     1500  -      -      -        -    -        0      0
40   enet  100040     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        1      1003
1003 tr    101003     1500  1005   0      -        -    srb      1      1002
1004 fdnet 101004     1500  -      -      1        ibm  -        0      0
1005 trnet 101005     1500  -      -      1        ibm  -        0      0
Hi ,
By default, all VLANs are allowed to transit a trunk link.  They are considered to be in the 'allowed list' for that trunk.
sh int fa0/3/0 trunk | begin allowed
issue this command & tell what its showing .
its something like this
Trunking VLANs Enabled: 10,20,30,40,1002-1005
Ritesh Malviya
router#sh interfaces fastEthernet 0/3/0 trunk | begin allowed
Port      Vlans allowed on trunk
Fa0/3/0   1-1005
Port      Vlans allowed and active in management domain
Fa0/3/0   1,10,20,30,40
Port      Vlans in spanning tree forwarding state and not pruned
Toma ,
Where are the users connected ? Is there any switch in your setup ?
Dan
It's a non cisco switch. I want to connect the switch on the router in feth0/3/0 and the users are connected in the switch.
Does your non-cisco switch support vlans and trunking ?
You need to configure on this switch, on the port connected to the router, trunking ( vlan tagging )
Also you have to have the vlans configured on this switch. Furthermore you will need to configure each switch port, as an access port ( no tag )
Dan
If i configure each port from HWIC-4ESW module :
feth0/3/0 VLAN 10
feth0/3/1 VLAN 20
feth0/3/2 VLAN 30
feth0/3/3 VLAN 40
in access mode
and connect them in the switch it's a problem ?
I have done this but I think it's not a good way because it's making a loop in the network and the router gives some messages:
*Mar 20 09:50:21.311: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discover
ed on FastEthernet0/3/1 (20), with router FastEthernet0/3/0 (10).
*Mar 20 09:50:32.999: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discover
ed on FastEthernet0/3/0 (10), with router FastEthernet0/3/1 (20).
Also, in this switch is connected other 3 switches, each one on 3 floors in the building where are diffrent departments.
The idea is that i want to limit bandwith just for VLAN 20 and 30 ( usual clients) and VLAN 10 and 40 without bandwith limiting for IT and othe clients that uses static ip's from VLAN 10 and 40 and I think of this like a solution to do it.
Petrut,
You can use this setup with access ports, but the router ports connected the switche should be configured as access (not tagged)  for the required VLAN.
If I understood well you have already in place vlans on your switches. Correct me ? Or did you uses different IP addresses on the same broadcast domain, and your switch does not support vlans ?
Dan
I know that the switch directly connected to the router is a
D-link DES-1228 Web Smart 24-Port 10/100 + (4) 1000BASE-T Ports + 2 Combo Ports Switch
Sadly this is a Cisco Support Forum
Have a look at :
http://forums.dlink.com/index.php?action=printpage;topic=7412.0
Having a quick look you will have to :
config vlan vlan10 add tagged 1
config vlan vlan20 add tagged 1
config vlan vlan30 add tagged 1
If the router is connected to the Switch port 1.
I will not discuss furthermore D-Link configuration issues.
Dan
