Acitve Backup interface
sukhjits8511
Hi cisco gurus.....
can anyone explain me what does the command
Active Backup interface means....
and how is it different from simple backup interface command.
Thanks in advance
are you referring to the command:
backup active interface
? If so, this command is used in the context of X.25, in order to activate a dual serial line, one active and one backup.
Check the explanation in the command reference
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/wan_r/wan_a1g.htm#wp1035673
HTH,
GP
