ACL allowing internet but blocking rfc addresses
leepippins
I have multiple subinterfaces on a router. One of the subinterfaces will be for guest access to the internet. I want to allow these users access to the internet but block them from our internal resources on other subinterfaces as well as corporate resources across the mpls/bgp network. Is this the best way to accomplish this? The path to the internet is across the mpls circuit.
interface GigabitEthernet0/0
 description LAN
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 description DATA
 encapsulation dot1Q 10
 ip address 10.10.100.1 255.255.255.0
 ip wccp redirect exclude in
interface GigabitEthernet0/0.20
 description VOICE
 encapsulation dot1Q 20
 ip address 172.16.100.1 255.255.255.0
 ip wccp 61 redirect in
interface GigabitEthernet0/0.30
 description GUEST
 encapsulation dot1Q 30
 ip access-group 199 in
interface s0/0/0:0
 description ATT MPLS
 ip address 68.2.4.8 255.255.255.248
 ip flow ingress
 ip flow egress
access-list 199 deny   ip 192.168.1.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 199 deny   ip 192.168.1.0 0.0.0.255 172.0.0.0 0.31.255.255
access-list 199 deny   ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 199 permit ip 192.168.1.0 0.0.0.255 any
Notice access-list 199 applied inbound interface g0/0.30.
I also use these private networks quite often in ACLs. For that, one of my first copy/pastes to a new router is the following object-group:
object-group network RFC1918
 10.0.0.0 255.0.0.0
 172.16.0.0 255.240.0.0
 192.168.0.0 255.255.0.0
This object-group can then be used in the ACLs:
ip access-list extended XXX
 deny   ip any object-group RFC1918
 permit ip YOUR-NETWORK any
Effectively it's the same as your ACL. For the "deny" I would use the source of "any" as it also prevents spoofed addresses.
Jon Marshall
Are you really using all the internal private ranges ?
Regardless yes your acl will work except your 172.x.x.x entry is wrong ie. it should be "172.16.0.0 0.15.255.255"
Jon
Thank you for the correction Jon. While we do not use all of the private ranges, we use a bunch. Wouldn't want to have to come fix this acl if we ever added something new later. Easier to cover the whole range now I think.
 10.0.0.0 255.0.0.0
