Cisco 2901 router multiple vpn tunnels
JMJZaman69
Hi Guys,
I have an issue with Cisco 2901
I need to connect to 2 sites from the main office
However when the 2nd site connects i lose the first VPN.
does the 2901 support 2 site to site VPN connections ?
Thank you kindly for viewing
Matthew
Not seen such case, I think its related to config.
Thank you for quick eyes  but config below seems okay
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp policy 2
    encr aes 256
 group 2
crypto isakmp key THEKEYTOSITE1 address SITE.ONE.xx.xx
crypto isakmp key THEKEYTOSITE2 address SITE.TWO.x.xx
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
 mode tunnel
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
 mode tunnel
rypto ipsec transform-set SITETWO esp-aes 256 esp-sha-hmac
 mode tunnel
crypto map SITEONE 1 ipsec-isakmp
 description Tunnel SITEONE
 set peer x.x.x.x
 set transform-set ESP-3DES-SHA1
 match address 103
crypto map SITETWO 1 ipsec-isakmp
 description Tunnel SITETWO
 set peer x.x.x.x
 set transform-set SITETWO
 match address 104
interface GigabitEthernet0/1
 description external WAN
 ip address xxx.x.xxx.xx xxx.xxx.xxx.xxx
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 crypto map SITEONE
crypto map SITETWO
ip nat inside source route-map SITEONE interface GigabitEthernet0/1 overload
ip nat inside source route-map SITETWO interface GigabitEthernet0/1 overload
route-map SITEONE permit 1
 match ip address 104
route-map SITETWO permit 1
Problem is bcos you are applying two crypto-map on single interface.
Use nested config.
