ACL Between 2851 and Consumer Netgear
Jeff
Hello All,
I have a very elementary ACL question, but for the life of me I can not get it to work.  My home lab scenario is this;
I have a specific computer (SERVER A) on my 192.168.20.x network, and I do not want it to be able to access the Internet, which is accessible through my consumer Netgear router at 192.168.0.1.  In between the 192.168.20.x network and the 192.168.0.x network is a Cisco 2851. The 2851 has the default static route set to 192.168.0.1, the address of the Netgear router. However, both networks need to be able to communicate with the server internally.  Below is a sketch of the network.
SERVER A -------- (INT GI0/1 ------INT GI0/0) ----------------(NETGEAR ROUTER 192.168.0.1)-----------INTERNET
                                   2851 ROUTER
   deny tcp host 192.168.20.20 host 192.168.0.1
   deny ip host 192.168.20.20 host 192.168.0.1
   permit ip any any
I figured I probably needed to apply it to the gi0/0 interface since the routing process would be sending it out that interface, however neither direction is blocking the attempt to access the Internet.
Any suggestions is greatly appreciated.
cadet alain
HI,
ip access-list extended NO-INTERNET
permit ip  192.168.20.0 0.0.0.255 192.168.0.0 0.0.0.255
deny ip host 192.168.20.20 any
permit ip any any
int g0/1
ip access-group NO-INTERNET in
Alain
kcnajaf
Level 7
Level 7
Hi Jeffrey,
The default gateway address on the server/PC is the ip address on the interface Gi0/1..right?
If that is the case try applying above ACL on Gi0/1 in inbound direction.
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
cadet alain
HI,
permit ip any any
int g0/1
Alain
Thanks guys, Cadet Alain's config did the trick.
