ACL blocks telnet, but it shouldn't, please help!
Istvan kelemen
Hi all,
I have problem with ACL, acl 110 blocks telnet to cisco1 vtp domain to cisco2 and vice versa, however i can telnet to the touter on the top.
And i have an other problem too.. I've tried ospf, eigrp, ripv2. Those didn't work properly the routers didn't learn the full routing table.
Of course split horizont is off. Static route worked fine...
I't a point to point frame relay, R1 is the hub, the 2 routers below are the spokes.
I've attached the packet tracer file, if you want to take a look
interface Serial0/0/0.1 point-to-point
ip address 192.168.1.254 255.255.255.0
no ip split-horizon
frame-relay interface-dlci 102
ip access-group 110 in
ip nat inside
clock rate 2000000
interface Serial0/0/0.2 point-to-point
ip address 192.168.2.190 255.255.255.192
no ip split-horizon
frame-relay interface-dlci 103
ip nat inside
clock rate 2000000
access-list 110 permit tcp any any eq 443
access-list 110 permit tcp any any eq www
access-list 110 permit tcp 172.16.20.0 0.0.0.127 host 10.10.10.254 eq ftp
access-list 110 permit tcp any any eq domain
access-list 110 permit udp any any eq domain
access-list 110 permit tcp any any eq telnet
Any help is welcome.
Thanks in advance!
2 Accepted Solutions
Because packets goes to the router which you do telnet but cannot go back. So to make it work you need to add additional rule to permit return traffic from remote router.
access-list 110 permit tcp any eq telnet any
Problem also in ACL #110. You need to permit dynamic routing protocol traffic (OSPF, EIGRP).
access-list 110 permit eigrp any any
Additional you could permit traffic ICMP traffic for diagnostic purpose.
access-list 110 permit icmp any any
Any access-list in Cisco IOS has at the end of ACL has deny any any default rule.
And above link I posted explains this. I just wanted you to find out it by yourself.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
No, actually it permits telnet traffic that goes to the remote router only. It means from any source to any destination device that runs Telnet service. And it's applied inbound direction it means packets go through ACL that entering to interface.
Telnet service on the router will be source of packets that responds to destination router.
And when device responds to that source(that requested connection) it's packets get blocked(deny any  any, at the end of ACL) because there is no match in ACL.
So permit tcp any eq telnet any permits those traffic from remote router.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
9 Replies 9
Abzal
Level 7
Level 7
Have a look on these links try to understand ACL in Cisco IOS then you will solve your problem
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml#proacl
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml#applyacls
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
thanks i'll ready them!
but the question is still open
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
thanks it worked fine!
oh thanks, i alwas have problem with traffic which is coming back <3 bro!
abut the routing problem, i had problem with it before i set the acl up
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
one more question sir!
the acl under is filtering inbound traffic from the internet
if i use those commands hosts from the internet can access ftp,hhtp,https services on my whole inside network
but if i change the highlighted "any" to host 10.10.10.254 which is my inside server, the hosts from the internet cannot access my inside server anymore
access-list 150 permit tcp any any established
access-list 150 permit tcp any any eq ftp
access-list 150 permit tcp any any eq www
access-list 150 permit tcp any any eq 443
anyway there is an inside outside nat rule+port forwarding
global adress is 198.0.18.9 local is 10.10.10.254
If ACL #150 is applied on Internet facing interface you need to use public IP instead of private.
Note. For security reason I would not recommend to use any statement in ACL that applied on outside interface and also would not recommend to post here real public IP for the same reason.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
it is a packe tracer lab, so dont worry m8
