ACL clarification
Raja_D
Level 5
Level 5
Can someone explain the major difference between the below commands:
deny tcp host x.x.x.x any
deny ip host x.x.x.x any
James..
Georg Pauwen
James,
IP works at the network layer (3) of the OSI model, TCP at the transport layer (4). That means:
will block anything originating from the specified host to anywhere.
TCP is used by e.g. HTTP, HTTPs, FTP, SMTP, Telnet. You can block these selectively and still allow e.g. UDP (which operates at the same layer as TCP), such as DNS, DHCP, TFTP, SNMP, RIP, VOIP..
So in short:
deny ip host x.x.x.x any --> blocks everything
deny tcp host x.x.x.x any --> blocks only TCP, but allows UDP
Thanks George for the clarification..
James..
