problem connecting Cisco 867VAE router with VDSL2/ADSL2+ over POTS
issambayar
Hi ,
i have problem connecting Cisco 867VAE this is my config and my diagnostic file ( IOS version ==> c860vae-ipbasek9-mz.151-4.M4.bin )
diag file :
sBelfort#sh atm int atm0
Interface ATM0:
AAL enabled:  AAL5,, Maximum VCs: 2, Current VCCs: 0
VCIs per VPI: 1024,
Max. Datagram Size: 2096
PLIM Type: ADSL - 4608Kbps Upstream, DMT, TX clocking: LINE
0 input, 0 output, 0 IN fast, 0 OUT fast
Avail bw = 4608
Config. is ACTIVE
sBelfort#sh ip int brief
Interface                  IP-Address      OK? Method Status                Prot        ocol
ATM0                       unassigned      YES NVRAM  down                  down
ATM0.1                     unassigned      YES unset  down                  down
Dialer0                    unassigned      YES NVRAM  up                    up
Ethernet0                  unassigned      YES NVRAM  administratively down down
FastEthernet0              unassigned      YES unset  down                  down
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  up                    up
FastEthernet3              unassigned      YES unset  up                    up
GigabitEthernet0           unassigned      YES NVRAM  administratively down down
NVI0                       unassigned      YES unset  administratively down down
Vlan1                      192.168.1.1     YES NVRAM  up                    up
sBelfort#show atm vc
Codes: DN - DOWN, IN - INACTIVE
           VCD /                                            Peak Av/Min Burst
Interface  Name         VPI   VCI Type    Encaps     SC     Kbps   Kbps Cells St
0.1        1              8    35 PVC     SNAP       UBR       0              IN
sBelfort#sh inter atm0.1
ATM0.1 is down, line protocol is down
  Hardware is BCM6300 ATMSAR, address is 70ca.9bbd.f0b7 (bia 70ca.9bbd.f0b7)
  MTU 2038 bytes, BW 4608 Kbit/sec, DLY 80 usec,
  Encapsulation ATM
  Keepalive not supported
     0 packets input, 0 bytes
     0 packets output, 0 bytes
     0 OAM cells input, 0 OAM cells output
  AAL5 CRC errors : 0
  AAL5 SAR Timeouts : 0
  AAL5 Oversized SDUs : 0
sBelfort#show controller vdsl 0
Controller VDSL 0 is UP
Daemon Status:           NA
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'BDCM'
Chip Vendor Specific:   0x0000                   0xA19B
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   'BDCM'
Modem Vendor Specific:  0x4602                   0xA19B
Modem Vendor Country:   0xB500                   0xB500
Serial Number Near:    GMK1148001K 867VAE   15.1(4)M
Serial Number Far:
Modem Version Near:    15.1(4)M
Modem Version Far:     0xA19B
Modem Status:            TC Sync (Showtime!)
DSL Config Mode:         AUTO
Trained Mode:            G.993.2 (VDSL2) Profile 12a
TC Mode:                 PTM
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Trellis:                 ON                       ON
Line Attenuation:         0.0 dB                  0.0 dB
Signal Attenuation:       0.0 dB                  0.0 dB
Noise Margin:            14.1 dB                  7.6 dB
Attainable Rate:        41364 kbits/s            1997 kbits/s
Actual Power:            14.5 dBm                 4.8 dBm
Per Band Status:        D1      D2      D3      U0      U1      U2      U3
Line Attenuation(dB):   21.9    55.9    N/A     N/A     51.5    59.1    N/A
Signal Attenuation(dB): 21.9    55.9    N/A     N/A     50.9    N/A     N/A
Noise Margin(dB):       14.0    14.3    N/A     N/A     7.6     N/A     N/A
Total FECS:             54445                    0
Total ES:               0                        0
Total SES:              0                        0
Total LOSS:             0                        0
Total UAS:              24                       24
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
Bit swap:               0                        1
Full inits:             1
Failed full inits:      0
Short inits:            0
Failed short inits:     0
Firmware        Source          File Name (version)
VDSL            embedded        N/A (0)
Modem FW  Version:      23i
Modem PHY Version:      A2pv6C032b.d23i
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             0            21399             0              1017
Previous Speed:           0                0             0                 0
Reed-Solomon EC:          0            54445             0                 0
CRC Errors:               0                0             0                 0
Header Errors:            0                0             0                 0
Interleave (ms):       0.00            19.00          0.00              0.00
Actual INP:            0.00             8.01          0.00              0.00
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
debug atm errors
debug pppatm errors
debug pppatm events
debug ppp neg
debug ppp auth
debug ppp err
*Apr  4 14:33:42.887: (atm_vc_is_bridged_dot1q)ATM: VC with handle 0x0 not found
*Apr  4 14:33:42.887: VC micro block get: Invalid vc handle
*Apr  4 14:33:44.935: (atm_vc_is_bridged_dot1q)ATM: VC with handle 0x0 not found
*Apr  4 14:33:44.935: VC micro block get: Invalid vc handle
*Apr  4 14:33:46.983: (atm_vc_is_bridged_dot1q)ATM: VC with handle 0x0 not found
can anyone help me please
The reason I ask is that it looks like the VDSL controller has connected using G.993.2 (VDSL2) Profile 12a.
Try forcing the controller to connect at ADSL2+ using the commands:
Router(config)# controller vdsl 0
Router(config-controller)# operating mode adsl2+
Router(config-controller)# end
as explained at
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/routconf_external_docbase_0900e4b18060bb55_4container_external_docbase_0900e4b18232995d.html#wp1189418
and repost the output of show controller vdsl 0
7 Replies 7
kmccourt
Are you trying to configure this for ADSL or VDSL?
hi,
via ADSL and i have a router Dlink RangeBooster N ADSL2+ Router DSL-2750B up and running on it !
as explained at
On the other hand, if router connects in VDSL2 mode, perhaps that would be better to use and give better performances.
OP can check with ISP about tthat.
the problem is that d-link router is configured as adsl ( atm ) and it's working perfectly!!!
now i forced the vdsl controller ...the probleme is resolved ,thx to all
thank you so much, you have saved my life
I had the same scenario with problem above, and configured with "operating mode adsl2+" and works fine, just need to verify, does adsl2+ stable configuration for permanent solution?
Because i read cisco documentation stated auto mode is recommended, but for my case i doesn't able to dial up while using auto mode.
Refer attachment with screenshot from cisco documentation.
Configuring ADSL Mode
http://www.cisco.com/c/en/us/td/docs/routers/access/800/software/configuration/guide/SCG800Guide/SCG800_Guide_BookMap_chapter_010.html#task_1163169
