ACL Counts - Same ACL shared across interfaces
pbelletty
I have a router where the same ACL is applied across several interfaces.
I would like to know the ACL counts/matches for each individual interface. Is this possible?
I don't believe it is  but would appreciate your views.
Look forward to hearing from you,
Phil
Hi Phil,
Have you tried the following command for each interface?
show ip access-list interface fa0/0 in ( if the interface is fastethernet 0/0 and direction is IN)
Here is sample output:
Router# show ip access-list interface FastEthernet 0/1 in
 Extended IP access list 150 in
  10 permit ip host 10.1.1.1 any (3 matches)
  30 permit ip host 10.2.2.2 any (12 matches)
HTH,
Meheretab
HTH,
Meheretab
Julio E. Moisa
Hi Phil,
This link could be useful, usually the ACLs show the matches for all interfaces if you execute show access-list....
http://www.techrepublic.com/blog/data-center/how-to-view-cisco-ios-acl-statistics/
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
