02-14-2018 04:13 PM - edited 03-05-2019 09:56 AM
I'm struggling to make a tweak to our ASA5505. A consultant built the original config, and he's no longer available or interested.
I'm trying to open an outbound TCP port to a single IP address, and I just can't find the formula. There aren't any examples in the existing config. I want the entry to be in the second entry. I'm typing
"access-list inside_out extended line 2 permit tcp any host bozo.245.22.71.114 eq 8074"
and I get a response of "invalid input at "^"" where the "^" it at the right margin. I've tried adding an "out" on the end with no change to the result. bozo... is listed in the name section, although I added it. Do you have to "execute" to have a running-config take effect? I struggled last time I did a similar task and gave up and opened an IP without respect to port, which seems an unnecessary risk.
Solved! Go to Solution.
02-14-2018 05:12 PM
Try with:
access-list inside_out line 2 extended permit tcp any host bozo.245.22.71.114 eq 8074
I have not used words along with an IP address before, so it should be:
access-list inside_out line 2 extended permit tcp any host 245.22.71.114 eq 8074
02-14-2018 05:12 PM
Try with:
02-14-2018 07:57 PM
Thx. The order of line/extended fixed it. So much for my Network Professional's Library guidebook! Should have been obvious from the show version, but I trusted the book.
