No UDP protocol thru L2tpv3 tunnel
David Ritter
Level 4
Level 4
I need to establish a L2tpv3 tunnel between a pair of 4321's connected via AT&T L2 ASE link.
I have no issues passing TCP traffic, but UDP traffic is rejected.
the ios XE ios is 3.14.00.s and the interface be:
interface GigabitEthernet0/0/1
description L2-L2TP-INT
no ip address
negotiation auto
xconnect 172.25.xx.xx 1 encapsulation l2tpv3 pw-class INET
any suggestions?
I think you need to configure 'ip protocol udp' under your pseudowire class...
ah too bad the only choice is
ip protocol l2tp or ip protocol uti.
and when you l2tp, nothing gets save when one writes mem..
existing cfg:
pseudowire-class INET
ip local interface GigabitEthernet0/0/0
ip pmtu
ip dfbit set
The problem was resolved to excessive fragmentation.
The MTU was raised to max and the problem was gone.
45mbps bidirectional on average tcp and udp.
