ACL hostname
Hello
I would like to make a ACL with hostnames.   The problem is that the router only looks at the hostname to Ip when i insert the command.
How can i use a hostname in an acl that would change the Ip when it has changed.
So the router should look for the hostname and if it has changed the ACL should also be changed.
How can i make this?
Milos Megis
Level 3
Level 3
as long as I know you cannot achieve this with ACL
