ACL in Single line
Rupesh Kashyap
Hi, I have to allow tcp 45.194.169.115 , 61.202.173.243, 14.234.41.250 to any eq 443. But I have use ACL in Single line only. Please help what should be ACL...
6 Replies 6
Rupesh,
I can't do that in a single line. I can do with a single ACL configured with 3 ACEs.
ip access-l ex TEST
permit tcp host 45.194.169.115 any eq 443
permit tcp host 61.202.173.243 any eq 443
permit tcp host 14.234.41.250 any eq 443
HTH,
Toshi
rpfinneran
This cannot be accomplished in one line. As noted above, you must use 3 lines if you only want to allow the specified hosts.
Leo Laohoo
As what the others have posted, you can't put different hosts in ONE ACL statement.
You can, on the other hand, put in one statement a group of ports in an extended access list.
Hi, I heard this may be like--
14.194.41.114 20.40.132.137 (E.g Network ID and Wild Card). Any idea?//
jennyjohn
I believe it is
permit tcp 12.194.41.114 49.40.132.137 any eq 443
& permit tcp 12.194.41.114 206.215.123.118 any eq 443    on an ASA
Very intresting question, have to go down to binary level to do this
mlund
Level 7
Level 7
You can do it in one line as jennyjohn has wrote it.
But I think jennyjohn missed one bit, it should be
permit tcp 12.194.41.114 51.40.132.137 any eq 443  on an ios router
or
permit tcp 12.194.41.114 204.215.123.118 any eq 443    on an ASA
/Mikael
