ACL Issue
libra_ali786
I am trying to block 192.168.0.0 to 192.168.3.255 network by standard ACL but permit the 192.168.4.0 and 10.10.10.0 network. My ACL  access-list 15 deny 192.168.0.0 0.0.3.255 , but unfortunaitly i unable to ping from my 192.168.4.0 network also when i try to ping from 10.10.10.0 geting the
R1#ping 20.20.20.1
Sending 5, 100-byte ICMP Echos to 20.20.20.1, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
My R1 Configuration
R1#
interface Loopback1
no ip address
shutdown
interface FastEthernet0/0
ip address 192.168.0.254 255.255.255.0
duplex half
interface GigabitEthernet1/0
ip address 10.10.10.1 255.255.255.0
negotiation auto
interface GigabitEthernet2/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet3/0
no ip address
shutdown
negotiation auto
interface FastEthernet4/0
ip address 192.168.1.254 255.255.255.0
duplex auto
speed auto
interface FastEthernet4/1
ip address 192.168.2.254 255.255.255.0
duplex auto
speed auto
interface FastEthernet5/0
ip address 192.168.3.254 255.255.255.0
duplex auto
speed auto
interface FastEthernet5/1
ip address 192.168.4.254 255.255.255.0
duplex auto
speed auto
router eigrp 1
network 10.10.10.0 0.0.0.255
network 192.168.0.0
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
network 192.168.4.0
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#
no ip address
shutdown
duplex half
ip address 10.10.10.2 255.255.255.0
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
ip address 20.20.20.254 255.255.255.0
ip access-group 15 out
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
network 20.20.20.0 0.0.0.255
no auto-summary
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Note : I ahve only one ACL.
2 Accepted Solutions
Jaderson Pessoa
@libra_ali786
Your acl need a "permit" statement, because there is a implicity deny under it.
access-list 15 permit ip any any
add the command above in your acl and test again.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Jaderson Pessoa
you're welcome. If possible, mark as solved. It will help other people with the same doubt.
Good look :)
Jaderson Pessoa
6 Replies 6
Jaderson Pessoa
@libra_ali786
Jaderson Pessoa
On a side note, the 'ip' keyword is not available on a standard access list.
So you need to use:
access-list 15 permit any any
libra_ali786
Thanks  @Jaderson Pessoa  you are right. I am forget to apply permit command.
Jaderson Pessoa
Good look :)
Jaderson Pessoa
it is very unclear what you are trying to accomplish:
--> I am trying to block 192.168.0.0 to 192.168.3.255 network by standard ACL but permit the 192.168.4.0 and 10.10.10.0 network. My ACL access-list 15 deny 192.168.0.0 0.0.3.255
Both the 192.168.0.0 and 192.168.3.0 subnets are connected to the same router, R1, while your access list is configured on R2.
What exactly do you want to block on which router ?
Hello
R1#ping 20.20.20.1
UUUUU
The above is an icmp unreachable response message from your ping with a code probably stating of host unreachable due to your current access-list.
What you are requiring with that current acl is not specific enough, If you wish to negate access from 192.168.3.0/24 subnet to 192.168.0.0/16 it would be most applicable to deny it this traffic as close to the source as possible so that would mean applying an acl on R1 fa5/0 interface with an extended access-list
Example:
ip access extened ACL_in
deny ip 192.168.0.0 0.0.255.255 any
permit ip any any
ip access extened ACL_out
deny ip any 192.168.0.0 0.0.255.255
permit ip any any
int fa5/0
ip access-group ACL_in IN
ip access-group ACL_out OUT
Kind Regards
Paul
