ASR9001 License Activation
abdulkarim041
Level 2
Level 2
I have install the license in ASR9001. I have install the MPLS package as well but  whenever I get the output os "Show License" it shows license is inactive as under.
RP/0/RSP0/CPU0:ios#sh license
Wed Jan 8 00:47:59.925 UTC
FeatureID: A9K-9001-AIP-LIC (Slot based, Permanent)
Total licenses 1
Available for use 1
Allocated to location 0
Active 0
Store name Permanent
Store index 1
Pool: Owner
Total licenses in pool: 1
Status: Available 1 Operational: 0
I have reload the router as well but result is the same .
Below is the output of "show install active"
Node 0/RSP0/CPU0 [RP] [SDR: Owner]
Boot Device: disk0:
Boot Image: /disk0/asr9k-os-mbi-6.5.2/0x100000/mbiasr9k-rp.vm
Active Packages:
disk0:asr9k-mini-px-6.5.2
disk0:asr9k-mcast-px-6.5.2
disk0:asr9k-mpls-px-6.5.2
disk0:asr9k-k9sec-px-6.5.2
Node 0/0/CPU0 [LC] [SDR: Owner]
Boot Device: mem:
Boot Image: /disk0/asr9k-os-mbi-6.5.2/lc/mbiasr9k-lc.vm
Active Packages:
Below is the output of "show install inactive"
RP/0/RSP0/CPU0:ios#sh install inactive
Wed Jan 8 00:47:46.440 UTC
Secure Domain Router: Owner
Boot Device: disk0:
Inactive Packages:
disk0:asr9k-fpd-px-6.5.2
disk0:asr9k-mgbl-px-6.5.2
disk0:asr9k-mpls-px-6.2.3
Boot Device: mem:
Inactive Packages:
Below is the output of "show platform"
RP/0/RSP0/CPU0:ios#sh platform
Wed Jan 8 00:48:35.445 UTC
Node Type State Config State
0/RSP0/CPU0 ASR9001-RP(Active) IOS XR RUN PWR,NSHUT,MON
0/0/CPU0 ASR9001-LC IOS XR RUN PWR,NSHUT,MON
0/0/0 A9K-MPA-20X1GE OK PWR,NSHUT,MON
below is the output of "show version"
RP/0/RSP0/CPU0:ios#sh version
Wed Jan 8 00:49:02.659 UTC
Cisco IOS XR Software, Version 6.5.2[Default]
Copyright (c) 2019 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 3.04(20160331:102636) [ASR9K ROMMON],
ios uptime is 10 minutes
System image file is "bootflash:disk0/asr9k-os-mbi-6.5.2/0x100000/mbiasr9k-rp.vm"
cisco ASR9K Series (P4040) processor with 8388608K bytes of memory.
P4040 processor at 1500MHz, Revision 3.0
ASR-9001 Chassis
2 Management Ethernet
20 GigabitEthernet
4 TenGigE
4 DWDM controller(s)
4 WANPHY controller(s)
219k bytes of non-volatile configuration memory.
2868M bytes of hard disk.
3915760k bytes of disk0: (Sector size 512 bytes).
Configuration register on node 0/RSP0/CPU0 is 0x2102
Boot device on node 0/RSP0/CPU0 is disk0:
Package active on node 0/RSP0/CPU0:
iosxr-security, V 6.5.2[Default], Cisco Systems, at disk0:iosxr-security-6.5.2
Built on Sat Feb 2 13:56:07 UTC 2019
By iox-ucs-017 in /auto/srcarchive13/prod/6.5.2/asr9k-px/ws for pie
asr9k-k9sec-supp, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-k9sec-supp-6.5.2
asr9k-k9sec-px, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-k9sec-px-6.5.2
Built on Sat Feb 2 13:56:19 UTC 2019
iosxr-mpls, V 6.5.2[Default], Cisco Systems, at disk0:iosxr-mpls-6.5.2
Built on Sat Feb 2 14:00:39 UTC 2019
asr9k-mpls-px, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-mpls-px-6.5.2
Built on Sat Feb 2 14:00:55 UTC 2019
iosxr-mcast, V 6.5.2[Default], Cisco Systems, at disk0:iosxr-mcast-6.5.2
Built on Sat Feb 2 13:55:35 UTC 2019
asr9k-mcast-supp, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-mcast-supp-6.5.2
asr9k-mcast-px, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-mcast-px-6.5.2
Built on Sat Feb 2 13:55:47 UTC 2019
iosxr-infra, V 6.5.2[Default], Cisco Systems, at disk0:iosxr-infra-6.5.2
Built on Sat Feb 2 13:56:25 UTC 2019
iosxr-fwding, V 6.5.2[Default], Cisco Systems, at disk0:iosxr-fwding-6.5.2
iosxr-routing, V 6.5.2[Default], Cisco Systems, at disk0:iosxr-routing-6.5.2
iosxr-diags, V 6.5.2[Default], Cisco Systems, at disk0:iosxr-diags-6.5.2
iosxr-ce, V 6.5.2[Default], Cisco Systems, at disk0:iosxr-ce-6.5.2
iosxr-common-pd-fib, V 6.5.2[Default], Cisco Systems, at disk0:iosxr-common-pd-fib-6.5.2
asr9k-cpp, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-cpp-6.5.2
iosxr-gcp-fwding, V 6.5.2[Default], Cisco Systems, at disk0:iosxr-gcp-fwding-6.5.2
asr9k-os-mbi, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-os-mbi-6.5.2
Built on Sat Feb 2 13:57:26 UTC 2019
asr9k-base, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-base-6.5.2
asr9k-fwding, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-fwding-6.5.2
asr9k-ce, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-ce-6.5.2
asr9k-diags-supp, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-diags-supp-6.5.2
asr9k-scfclient, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-scfclient-6.5.2
asr9k-mini-px, V 6.5.2[Default], Cisco Systems, at disk0:asr9k-mini-px-6.5.2
Built on Sat Feb 2 13:58:07 UTC 2019
Boot device on node 0/0/CPU0 is mem:
Package active on node 0/0/CPU0:
How I can activate the license?
BR
Abdul Karim
how did you iinstall the license ? Make sure it is available at all locations of the router:
ASR9001(admin-config)# license A9K-9001-AIP-LIC location all
Also, post the output of:
ASR9001#admin show run license A9K-9001-AIP-LIC
Hi Georg,
Thank you so much for your kind response.
Below is your requested information
RP/0/RSP0/CPU0:ios#admin show run license A9K-9001-AIP-LIC
Wed Jan 8 03:14:28.810 UTC
% No such configuration item(s)
As per following link" For release 4.3.1 and later, you do not need to configure the license to bind to a slot or
to all slots. By default the licenses are available to all slots"
https://www.cisco.com/c/dam/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/asr9000-swe-user-whitepaper.pdf
Have a look on following output as well
RP/0/RSP0/CPU0:ios(admin-config)#
RP/0/RSP0/CPU0:ios(admin-config)#license A9K-9001-AIP-LIC location all
% Invalid input detected at '^' marker.
RP/0/RSP0/CPU0:ios(admin-config)#license A9K-9001-AIP-LIC location ?
0/0/CPU0 Fully qualified location specification
0/PS0/M0/SP Fully qualified location specification
0/PS0/M1/SP Fully qualified location specification
0/RSP0/CPU0 Fully qualified location specification
WORD Fully qualified location specification
Now advise what to do?
BR
Abdul Karim
how did you install the license ? Did you use smart licensing or traditional licensing ? Have a look at the document below, it might give you a few pointers...
https://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/200011-Smart-Licensing-on-the-ASR9000-Platform.html
