ACL not denying traffic
sejamc71
I don't have a lot of experience with ACLs and I am trying to create an ACL on a switch that will block a specific subnet from accessing the other networks on the switch.
Network management IP of switches 10.0.22.0/23
switch A Mgmt IP 10.0.22.1
Switch L3 interfaces 172.16.22.0/23 - wired, 10.0.22.0/23-wireless mgmt, 10.0.24.0/23 - wireless and 10.10.24.0/23 - Guest
I want to create an ACL that will stop 10.10.24.0/23 from talking to the other subnets. I came up with the following, but it doesn't seem to be working.
L3 Interface Config
interface GigabitEthernet0/0/2.1124
description SBI-Guest
encapsulation dot1Q 1124
ip address 10.10.24.1 255.255.254.0
ip access-group Guest-Access in
ip helper-address 172.16.22.24
no ip redirects
ACL config
ip access-list extended Guest-Access
permit udp any any eq bootpc
permit udp any any eq bootps
permit udp any any eq domain
deny ip 10.10.24.0 0.0.0.255 10.0.0.0 0.255.255.255
deny ip 10.10.24.0 0.0.0.255 172.16.0.0 0.15.255.255
deny ip 10.10.24.0 0.0.0.255 192.168.0.0 0.0.255.255
permit ip any any
permit tcp any any
Any thoughts on why this is not working?
24 Replies 24
ip access-group Guest-Access OUT
Only change the direction of acl
Thank you, I will try that
sejamc71
That did not seem to work. I am still able to ping between subnets
no ip redirects
ip access-group Guest-Access out
But the interface is 255.255.254.0
Match then and it sure work
sejamc71
so I changed my ACL to the following, but still able to ping between subnets
permit ip any any
permit tcp any any
deny ip 10.10.24.0 0.0.0.254 10.0.0.0 0.255.255.255
deny ip 10.10.24.0 0.0.0.254 172.16.0.0 0.15.255.255
deny ip 10.10.24.0 0.0.0.254 192.168.0.0 0.0.255.255
deny ip 10.10.24.0 0.0.1.255 10.0.0.0 0.255.255.255
This what must be it wildcard for 255.255.254.0
Hello
I want to create an ACL that will stop 10.10.24.0/23 from talking to the other subnets. Any
So you have switch L3 SVI's, if so i would apply the ACL on the subnet you wish to deny from the other vlans.
ip access-list extended deny-subnets
deny ip any 10.0.22.0 0.0.1,255
deny ip any 10.0.24.0 0.0.1,255
deny ip any 10.10.24.0 0.1.255
permit ip any any
Int vlan xx
ip address 172.16.0.22.x 255.255.254.0
ip access-group deny-subnets IN
Kind Regards
Paul
This is what I have
permit ip any any
permit tcp any any
deny ip 10.10.24.0 0.0.1.255 172.16.0.0 0.15.255.255
deny ip 10.10.24.0 0.0.1.255 192.168.0.0 0.0.255.255
no ip redirects
Hi so is it work or not ??
Sorry, it is not working. from a server on 172.16.22.xxx, I can ping the 10.10.24.1 subnet. I would think that I would not be able to ping from 172.16.22.xxx to the applicable subnet.
172.16.22.xxx >> 172.16.0.0 0.15.255.255  <<- this wildcard also have issue I think it must be 0.0.255.255
also share
show access-list <<- let see which line have hit count
I have an ACL in place. I am waiting on an onsite resource to do some testing. I have to be cautious so as to not cause a network outage or DHCP issue. I'm hoping to do more testing next week. If what I have doesn't work, I will try your ACL config above. Thank you
sejamc71
sh access-lists
Extended IP access list Guest-Access
10 permit udp any any eq bootpc
20 permit udp any any eq bootps (4 matches)
30 permit udp any any eq domain (778 matches)
70 permit ip any any (211908 matches)
80 permit tcp any any
90 deny ip 10.10.24.0 0.0.1.255 10.0.0.0 0.255.255.255
100 deny ip 10.10.24.0 0.0.1.255 172.16.0.0 0.15.255.255
110 deny ip 10.10.24.0 0.0.1.255 192.168.0.0 0.0.255.255
70 permit ip any any (211908 matches) <<- this hit
90 deny ip 10.10.24.0 0.0.1.255 10.0.0.0 0.255.255.255 <<- this not work  since you add it without line number and it take by default number below permit  ip any any
only remove totall ACL with
no access-list command
and enter the ACL again with correct line number and put the permit ip any any in end of ACL
NOTE:- make double check all wildcard you use in ACL
