Site to Site VPN tunnel adding EIGRP Conflicts
ironman28
We have a site to site VPN tunnel setup between the two ASAs, on the switches the ip route 0/0 goes to the firewall.  We will be adding a point to point connect between the two switches, would it be an issue if I have both of them running at the same time?  or should I just disable the site to site VPN tunnel first.   What is the easiest way to temporarily turn the site to site tunnel off?  Trying to avoid network loop or any issues.
If s2s is policy VPN it will have no effect on your rib
If it vti routing vpn then you need only in SW route for tunnel destination.
Thank you.
