ACL not working with NAT
menelskii
Hi all,
I have a problem with configuration ACL with NAT. When I remove ACL evrything is working correct. When I assing them to interface only ICMP-PING is working on computers connected to switch. It looks like packets goes to ISP and not comes back and computers have no access to Internet. Below You can find configuration of my devices. Have You any idea what is wrong?
==================== ROUTER =======================
version 12.4
hostname ROUTER
boot-start-marker
boot-end-marker
logging console informational
enable password cisco
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 10.1.2.1 10.1.2.10
ip dhcp pool VLAN100
   network 10.1.1.0 255.255.255.0
   dns-server 194.204.152.34 8.8.8.8
   default-router 10.1.1.1
ip dhcp pool VLAN200
   network 10.1.2.0 255.255.255.0
   default-router 10.1.2.1
ip dhcp pool VLAN300
   network 10.1.3.0 255.255.255.0
   default-router 10.1.3.1
voice-card 0
no dspfarm
username cisco password 0 cisco
archive
log config
  hidekeys
interface GigabitEthernet0/0
description INTERNET UPLINK
ip address XXX.YYY.169.250 255.255.255.248
ip access-group INCOME in
ip access-group OUTCOME out
ip nat outside
ip virtual-reassembly
duplex auto
speed 100
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
description VLAN 100
encapsulation dot1Q 100
ip address 10.1.1.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.2
description VLAN 200
encapsulation dot1Q 200
ip address 10.1.2.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.3
description VLAN 300
encapsulation dot1Q 300
ip address 10.1.3.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.10
description VLAN 1
encapsulation dot1Q 1 native
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 XXX.YYY.169.249
ip http server
no ip http secure-server
ip nat pool NAT-VLAN XXX.YYY.169.251 XXX.YYY.169.252 netmask 255.255.255.248
ip nat inside source list VLANS pool NAT-VLAN overload
ip nat inside source static 10.1.3.0 XXX.YYY.169.253
ip access-list extended INCOME
permit tcp any any eq www
permit tcp any any eq 443
permit udp host 194.204.152.34 any gt 1023
permit udp host 8.8.8.8 any gt 1023
permit tcp any any eq whois
permit icmp any any
permit esp any any
permit ahp any any
permit udp any any eq isakmp
permit udp any any eq 4443
permit udp any any eq non500-isakmp
permit udp any any eq 10000
permit tcp any any eq telnet
ip access-list extended OUTCOME
permit icmp any any
permit esp any any
permit ahp any any
ip access-list extended VLANS
permit ip 10.0.0.0 0.255.255.255 any
logging trap debugging
control-plane
banner exec ^CC
|                                WARNING                                |
banner motd ^CC
                                 WARNING
line con 0
password cisco
line aux 0
line vty 0 4
password cisco
login local
transport input telnet
scheduler allocate 20000 1000
end
=========================== SWITCH ===================================
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SWITCH
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 100
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
switchport access vlan 200
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
switchport mode trunk
interface GigabitEthernet0/2
switchport access vlan 300
interface Vlan1
ip address 10.10.10.2 255.255.255.0
no ip route-cache
interface Vlan100
ip address 10.1.1.2 255.255.255.0
no ip route-cache
shutdown
interface Vlan200
ip address 10.1.2.2 255.255.255.0
no ip route-cache
shutdown
interface Vlan300
ip address 10.1.3.2 255.255.255.0
no ip route-cache
shutdown
ip default-gateway 10.10.10.1
ip http server
banner exec ^CC
|                                WARNING                                |
banner motd ^CC
|                                WARNING                                |
line con 0
password cisco
line vty 0 4
password cisco
login local
line vty 5 15
login
end
2 Accepted Solutions
  Just think of the direction of packets.
For example  ,  Return packets from the internet
permit tcp any eq www any
permit tcp any eq 443 any
HTH,
Toshi
   Sorry for my late reply.  Sure you can telnet to the router.  When you write ACLs you have to think of the direction of packets you're going to filter.
   In router point of view  the packet going out will hit ACL-OUTCOME. You may think that packets are going to the internet. In your case packets are Natted before going to outbound-acl.  Let's say you allow  packets going to the internet for http/https/dns services.
  Source IP address : Actually it's an IP of WAN router(coz Natted) ,  ANY is okay
  Source Port : Any numbet  (should be >1023)
  Destination IP address : ANY (internet ) ,
Destination Port :  http/https/dns
  So the ACL should be as follows:
      Permit tcp any (Source IP , ANY port)  any (Destination Internet-IP) eq 80 (Destination Port)
       Permit tcp any (Source IP , ANY port)  any (Destination Internet-IP) eq 443 (Destination Port)
      Permit tcp any (Source IP , ANY port)  any (Destination Internet-IP) eq 53 (Destination Port)
  In router point of view  the packet comming in will hit ACL-INCOME. You may think that packets are comming from the internet. Let's say you  allow  packets comming from the internet for http/https/dns services.
F.e. Retured Packets
  Source IP address : ANY (internet )
  Source Porthttp/https/dns
  Destination IP address :Actually it's an IP of WAN router(coz Natted) ,  ANY is okay
  Destination Port :  Any numbet  (should be >1023)
      Permit tcp any (Source Internet-IP)  eq 80 (Source Port)  any (Destination Any Port)
       Permit tcp any (Source Internet-IP)  eq 443 (Source Port) any (Destination Any Port)
      Permit tcp any (Source Internet-IP)  eq 53 (Source Port)  any (Destination Any Port)
HTH,
Toshi
HTH,
Toshi
I forgot to write that I can connect with router by Telnet from internet with ACL assigned.
Toshi i never saw this kind of access list order. Always it was . Can You describe me a little what this change when I put "any" at the end? I tried to change all INCOME ACL whit this form You propose but only effect was that I blocked my telnet connection with router from internet. I thing I don't understand something. Should I do this only for www, https and dns or for evry position?
Luka
HTH,
Toshi
Toshi
Thanks very much for such detailed explanations. This improve my understanding about ACL a lot but still I have to learn a lot. I thing I looked at this problem from wrong point of view. Thanks again.
The good thing is that I start to make some changes with advices from Your first answer and I did "unprofessional" solution for my problem. I put any port rules twice. Like:
I did this only for my INCOME ACL assigned to ISP connection port in, and I deleted OUTCOME ACL and for now everything is working.
Now I'm going to sit down and thing about Your second post until I compleatly understand why this works and what is not needed.
