ACL not working with NAT
Jonasye
I'm studying on Cisco packet tracking, I just found one strange thing. I attached the network map and configuration below.
1> I created NAT for 10.2.0.0/16 and 10.3.0.0/16 to access the server0.
2> Created ACL for 10.2.100.0 0.0.0.255 to not allow access server www
     Created ACL for 10.3.100.0 0.0.0.255 to not allow access server ftp
Now the problem comes, the PC0 still can access the server www, same as PC2 can access FTP.
But if I deleve the nat command line, the ACL works.
I'm confused, the ACL should always work before NAT, it looks like the NAT bypassed the ACL with its outbound IP address without filtered. how does this happen???
interface FastEthernet0/0
 ip address 10.1.50.1 255.255.0.0
 ip access-group 110 out
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 10.2.1.1 255.255.0.0
 ip nat inside
 duplex auto
 speed auto
interface FastEthernet0/1.3
 encapsulation dot1Q 3
 ip address 10.3.1.1 255.255.0.0
 ip nat inside
interface Vlan1
 no ip address
 shutdown
ip nat pool internet 10.1.50.50 10.1.50.50 netmask 255.255.0.0
ip nat inside source list 2 pool internet overload
ip classless
ip flow-export version 9
access-list 2 permit 10.2.0.0 0.0.255.255
access-list 2 permit 10.3.0.0 0.0.255.255
access-list 110 deny tcp 10.2.100.0 0.0.0.255 host 10.1.1.1 eq www
access-list 110 deny tcp 10.3.100.0 0.0.0.255 host 10.1.1.1 eq ftp
access-list 110 permit ip any any
15 Replies 15
Hello
Apologes @Jonasye
I didn’t read your post correctly as such didn’t see the acl 110 applied to the nat rtrs outside interface .
Anyway you just need to simply amend the nat access-list 2 to negate nat for those host so then the access-list 110 will be read,.
This is due to the nat order of operation for domain nat which will read the nat acl before any routing is perfromed or any outbound acl is read - here
example:
no access-list 2
access-list 2 deny host 10.2.100.1
access-list 2 deny host 10.3.100.1
Kind Regards
Paul
