ACL on switch
John Stevens
I have some 6500 switches and would like to set up an isolation vlan, where ports on this vlan can only talk to a few servers on my network and unable to talk to anything else on the vlan or my network.  Is this possible on the switch level and if so how could i restrict access to a vlan to say 3 servers only?
Hello.
You may use Port ACL - http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/vacl.html
Hi Jhon,
There are several ways to accomplish this task:
1)  it can be done by Private vlan
2) vlan access map
3) L2 ACL or port ACL
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6000-series-switches/10601-90.html
kazim abbas
