Unable to get tunnel configured
Bobby Mazzotti
I have a 2911 that has a few existing IPSec tunnels and I'm looking to add one in except the encryptio is a little different. I will be using AES vs DES like the other transform sets. - This what I have configured except I still don't see the tunnel when I do sh crypto isakmp sa... What could I be doing wrong?
note: I also added the peer address to access-list 101, do I need to allow it through outgoing_to_source?
Configure ISKAMP Policy
   crypto isakmp policy 3
   encr aes 256
   authentication pre-share
   hash sha
   lifetime 86400
   group 2
Configure IPsec Transform Set
  crypto ipsec transform-set ESP-AES-SHA esp-aes 256 esp-sha-hmac
Specifies the interesting traffic to be encrypted
ip access-list extended outgoing_to_source
 permit ip 192.168.18.0 0.0.0.255 host 10.1.1.198
 permit ip 192.168.18.0 0.0.0.255 host 10.1.1.197
 permit ip 192.168.18.0 0.0.0.255 host 10.1.1.226
 permit ip 192.168.18.0 0.0.0.255 host 10.1.10.20
 permit ip 192.168.18.0 0.0.0.255 host 10.1.10.21
 permit ip 192.168.18.0 0.0.0.255 host 10.1.10.22
 permit ip 192.168.18.0 0.0.0.255 host 10.1.10.24
 permit ip 192.168.18.0 0.0.0.255 host 10.1.10.121
 permit ip 192.168.18.0 0.0.0.255 host 10.1.10.122
Specifies the pre-shared key "secretkey" which should be identical at both peers
 crypto isakmp key "secret-key" address 65.x.x.x no-xauth
Configure the Ipsec-isakmp
 crypto map vpn-map 1 ipsec-isakmp
set peer 66.x.x.x
set transform-set ESP-AES-SHA
match address outgoing_to_source
Apply the Ipsec-isakmp to interface
interface GigabitEthernet0/1
description ** Connection to internet **
ip address 174.x.x.x 255.255.255.248
ip access-group 101 in
ip access-group 131 out
ip flow ingress
ip nat outside
ip inspect standard in
ip virtual-reassembly
duplex auto
speed auto
crypto map vpn-map
Jon Marshall
Have you excluded the IPSEC traffic from NAT ?
NAT happens before IPSEC so unless you have specifically excluded that traffic from NAT then the 192.168.18.x source IPs will be translated to 174.x.x.x before your crypto map is checked and so won't match.
Edit - if you don't want to exclude it from NAT then you can modify your crypto map to have the source IP of 174.x.x.x but you would also need to modify the crypto map on the other device as well.
Jon
8 Replies 8
Jon Marshall
Jon
I do not believe so, and might be green to what you are asking. Would I need to create a deny ACL in order to prevent the NAT process?
These are the remote hosts I'm trying to reach -
Remote Hosts:  10.1.1.198
10.1.1.197
10.1.1.226
10.1.10.20
10.1.10.21
10.1.10.22
10.1.10.24
10.1.10.121
10.1.10.122
Security Profile: ESP-AES-256-SHA
                                Group 2
                                SHA
                                86400 Lifetime
edited
I'm a big fan now of VTI interfaces to do the site-to-site crypto stuff, added bonus of easily running ospf inside the tunnel etc.
Hey John,
I was able to get phase 1 going by denying nat to the host object-group. Phase 2 is not initiating so I'm waiting for the vendor to send me their config.
-B
Hi Bobby,
you are configuring the wrong ip in set peer command or pre-shared key. both should be same, please review it.
set peer 66.x.x.x
kazim abbas
Do I need to somehow deny the local subnet to the remote local lan I'm trying to access? If so, what would be the command for that?
Yes, you need to deny the traffic.
Can you post the current router configuration so I can see what your existing NAT configuration is as I don't want to break anything currently working.
Jon
